6 members (Chase91, MowingManiac, AMP, Willy Supercut, Peter9231, 1 invisible), 3,205 guests, and 912 robots.
by MikeDD - 12/02/26 09:45 AM
by NormK - 18/02/26 04:22 PM
by Bruce - 18/02/26 01:10 PM
by Bruce - 16/02/26 12:06 AM
Rover Thoroughbred Model 85
by Bruce - 15/02/26 11:59 PM
by Bruce - 15/02/26 11:49 PM
Victa Corvette 4016
by Bruce - 10/02/26 07:53 AM
Cox ride on
by NormK - 04/02/26 08:14 PM
Heres another trick
8mm bolt, cut the head off it and put a slot in the top with a hack saw.
Handy for putting motors on and of bases. Not so good for the later ones wit hthe long bolt behind the muffler as you need to use a different hole.
You can also clamp the bolt in the vice and fiddle with the motor, good for testing spark if youve had it flipped over on the bench messing with the coil or coil lead.
Doesnt matter if it gets a bit trashed, its easy to make another one.
This trick works for most mowers.
Trusty block of redgum. Set the height lever so its straight up and down. Tip the motor sideways and rest the height lever on the block of wood. Works on victas and rovers and the like.
Well I must say bob you are full of it.................advice that is. You do seen to know a few handy tricks. Good work.
You can also do the same with a 3/8 bolt for the later 4 strokes.
ChrisNO, Cliff Tracy, The Todd, jtw37, Rod Browning
17,856 Registered Users
Topics13,066
Posts107,278
Members17,857
PHP: 8.3.30 Page Time: 0.059s Queries: 21 (0.054s) Memory: 0.6329 MB (Peak: 0.6554 MB) Data Comp: Zlib Server Time: 2026-02-19 02:29:42 UTC
