0 members (), 775 guests, and 796 robots.
#38172 05/07/12 01:17 PM
Hello,
I have recently moved home. The area that i now have to mow is substantially larger than before - and it slopes moderately. bigshock I had been using a Honda HRC216HXA to do the job at the old place. Total overkill! When i bought it (for not very much admittedly) the seller told me it just needed a cable and the self propelled part would work fine. rolleyes I never bothered looking into it at the time because i only had a small flat area to mow.
Well, three years later, i did look into it the other day. The mower is a first generation HRC216HXA i am guessing, going on information i found on the internet. The serial no. is MZAN-6034956. As mentioned, there is no transmission cable present. I have MacGyvered some wire, wood and garden hose into a rough and ready cable with handle for testing purposes. This, i have attached to the control arm on the side of the transmission where the cable would normally attach to.
Sadly, the mower goes nowhere when i pull on the cable. WTF If i lift the back of the mower so that the rear wheels are clear of the ground, i can get them to turn intermittently. It is a bit hit and miss when i pull on the cable as to whether or not they turn, if you get my drift. On the ground however, the axle seems to lump around trying to engage the wheel(?).
Also from the internet, it is suggested that it could be the drive shaft between motor and transmission that is crook. I took the plastic cover off the shaft and inspected it whilst the mower was running, with and without the transmission engaged. It turns furiously when the mower engine is on. Engaging the transmission seems to have no effect upon its operation (normal i guess).
When working, can these transmissions propel the mower up a bit of a slope? They are a heavy mower! tired I would probably have a go at finding out what is wrong with - if it could take the load out of pushing it up hill. grin
I'll probably disassemble the wheel/axle/transmission assembly. What should i look out for when looking for the cause? Is it likely to be in the wheels, or in the actual transmission?
Any tips for troubleshooting and diagnosing? Information on these transmissions has been hard to come by.
Thanks,
Paul
Paul, I do not think you are approaching this repair job the right way, given the complexity of that mower. I suggest you begin by reading the owner manual carefully. You can download it here:
http://dl.owneriq.net/9/9da3d438-eee3-47a6-b571-b9bdab4040f6.pdf
First, you should look to see whether the transmission's output is actually driving, but the wheels are not rotating due to failure of the back wheels or the associated over-running clutches. These parts seem to fail frequently.
Second, you need to follow the owner manual's process for ensuring that the transmission unit's selector is moving properly into the drive position, on Page 43 of 84 in the manual. You need to ensure that the transmission is actually in gear when you test it. Put it into drive (so that the lever behind the transmission cover lines up with the engaged notch, as shown in the owner manual), secure it in that position with a wire or a screw, depending on which transmission you have, and see if it drives.
Third, see if the drive shaft is damaged. The fact that it spins does not tell us two things: whether it keeps spinning when the transmission is actually engaged; and whether the output side of the drive shaft is damaged (it spins if the input side works, but that does not tell us about the output side). There is a thriving industry selling replacement drive shafts for Honda self-propelled transmissions.
Fourth, the transmission may have slowly lost hydraulic fluid over the years, so that it now needs replenishment. Here is some information on the subject from the workshop manual:
http://i107.photobucket.com/albums/m314/Restrorob/Honda/HondaPushHydroService.jpg
You should follow that procedure to top up the transmission. Work on the transmission carefully and keep things surgically clean, or you will ruin the transmission. Note that the procedure for actually changing the fluid (rather than checking and topping up) involves removing the entire transmission from the mower, which is apparently rather like solving a complex Chinese puzzle in the dark wearing boxing gloves. Furthermore putting it back in is even more difficult, especially if you didn't take lots of pictures while you were taking it out.
If you reach the point where you have convincingly established that none of these four things is the problem, it is likely you have a serious internal transmission problem, which may be unaffordably expensive to overcome. Conversely if you find and fix the problem, for Pete's sake put a proper transmission cable on it, or you will ruin that transmission.
On the subject of going up hills, as I understand it the transmission can handle that within reason. It is not a friction drive device, it is a proper hydrostatic transmission. The load you put on it may affect how long the drive shaft, wheel ratchets and wheels last, though. That is why so many people are selling replacements for those parts on the internet.
StewFuchs, Gib, auProspector, R Faurie, Steve Mack
18,093 Registered Users
Topics12,750
Posts106,781
Members18,094
