1 members (looktall),
5,463
2,252
Hi to every one i have a old victa mustang,my problem is the catcher wont stay cliped on,i attached 2 photos showing the rear flap on the mower ,the flap comes out of its pocket and lets catcher drop off,on 1 photo i have put a spacer nut on shaft to stop the the rear cover slidin along ,what should be there ,where can i see orget a parts view of this flap help please
Posts: 2,738 Likes: 6
Gray, the photo's have not come through, try using the 5th button from the left in the reply box "upload inline image(s)"
If the mower in question is a Mustang of the 70's or early 80's, it uses a locking clip, which will need adjusting, if it is a later mustang, it may need a pressure spring replaced.
If it is the mower in your avatar image, then it is a VC-160, not a mustang, and requires different work.
If it is a VC-160 MKI or MKII, then it may need the handles adjusted, but more likely needs the flap adjusted, if it s a VC-160 MKIII then it will most likely need the handles adjusted, and maybe the flap.
If you could try again to get the pictures to load, I'm sure we can be of more help.
Cheers Ty
how the bloody hell do i edit my post
You can edit them while the "Edit" symbol is displayed immediately below the post. Just press the Edit symbol. If it doesn't appear, too much time has elapsed since you posted it, and you can't edit it.
If you ever have a major problem with something you've posted and want it deleted entirely, send a PM to a moderator.
Grumpy, I'm fairly sure for most members you can only edit a post before another post is added to the thread, once someone reply's only a moderator can edit the post.
Cheers Ty
Thanks Ty, that sounds familiar now that you've explained it so clearly.
No worries Grumpy, it's an easy one to forget!
Gray, if you want to put up the photo's, I would suggest making a new post, and ataching them inline.
Cheers Ty
Posts106,838
Members18,196
