1 members (looktall), 3,524 guests, and 1,299 robots.
#3303 05/10/06 12:36 AM
hi Bruce
I cleaned and fitted new diaphram, springs,shoe, and brass contacts..
starts first pull and the throttle control works good, when i push down on the throttle lever for power, it revs to the point where it sounds like it is going to take off.
Springs maybe..???
thanks
regards Frank
#3304 05/10/06 08:49 AM
briggsboy,
It sounds like it is an air leak if it is reving really high. If it is a power torque motor check large starter 'O'ring. bigshock
#3305 06/10/06 08:20 AM
hi Bruce
I put a o ring on and also one where the carby twists onto the block.
still reving for take off...
i know i am missing the ..washer that goes under the cam in the carby. would that course it to rev up for take off.
other than that. the throttle responds good relevent to where the lever is
regards Frank
#3306 06/10/06 09:12 AM
briggsboy,
The carby mounting block has two screws holding it onto the cylinder. Is it loose? confused
If so it also has an 'O'ring behind it. Try replacing it. yay
We have information on the carby in the Parts list and manual area. cheers
18,154 Registered Users
Members18,156
