4 members (Peter9231, Warrnambool GER, MowingManiac, 1 invisible), 2,209 guests, and 398 robots.
by MikeDD - 12/02/26 09:45 AM
by Bruce - 16/02/26 12:06 AM
Rover Thoroughbred Model 85
by Bruce - 15/02/26 11:59 PM
by Bruce - 15/02/26 11:49 PM
by Bruce - 15/02/26 11:42 PM
by MowingManiac - 15/02/26 12:40 PM
Victa Corvette 4016
by Bruce - 10/02/26 07:53 AM
Cox ride on
by NormK - 04/02/26 08:14 PM
Page 3 of 3 1 2 3
#3226 29/05/06 09:28 PM
James,
You have set ring gap on the correct side. yay
I would suggest that you remove the jet in the carby and check the float level. bigshock
When you put the two half's of the crankcase together did you use any gasket sealant. confused
#3227 30/05/06 09:12 AM
Hi Bruce,
I used gasket goo to join the two halves. cool
I will clean/adjust the carby as suggested.
BTW: I think I know why the engine spat a ring ... The ring pieces that I cleaned out of the exhaust where carbon black and the ring that remained was in the second grove and was steel faced (it had the spring under it as well) ... I think the rings must have been put in the wrong order and this would have caused the carbon black one to flap around (as it had no spring) and catch on the exhaust port ... ?? rolleyes
James
#3228 30/05/06 11:01 AM
James,
If they had the oil ring under the top ring(compression) that is why it broke as it should be under the bottom ring.
Let me know how it all goes. cheers
Page 3 of 3 1 2 3
Rod Browning, whodat76, HVP, alfie350, Goughy783
17,852 Registered Users
Topics13,065
Posts107,271
Members17,853
PHP: 8.3.30 Page Time: 0.038s Queries: 20 (0.032s) Memory: 0.6340 MB (Peak: 0.6569 MB) Data Comp: Zlib Server Time: 2026-02-16 01:55:36 UTC
