1 members (Olqualcast), 7,585 guests, and 397 robots.
#30971 19/11/11 04:33 AM
Is there any info on how to remove the cylinder on a Scott Bonnar 45?
I have looked but seemed to come up empty handed...
Some photos would be very handy..
Shifty...
Give a man a fish and he will eat for a day. Give a man a fishing rod and he will sit in a boat and drink cans all day!
Hi Shifty, Here is the info you require;
Removing the reel is not difficult. Here's how:
1. Remove the chain case cover screws.
2. Undo the nut on the chain tensioner and slide down to slacken the chains, then remove the joining links and cutter and drive chains
3. Remove the nut that holds the cutter sprocket
4. Using a gear-puller remove the sprocket and the half-moon key from its key-way (keep it safe for replacement later)
5. Remove the upper halves of the cutter bearing holders by undoing the 2 screws on each.
6. Now looking at the cutter reel from the front....lift the reel from left hand side and slide up and out of the machine.
7. Remove the soleplate with bottom blade attached.
Your done!
Replacement is the reverse of the above procedure.
However, before replacement, don't forget to loosen all nuts on the adjusters and wind both up so that the new reel doesn't contact the bottom blade during replacement. wink
Please let us know how you get on Shifty, and best of luck.
Beautiful info!
Thank you....
18,218 Registered Users
Topics12,774
Posts106,874
Members18,219
