0 members (), 10,481 guests, and 394 robots.
Dear All
I have got a Kartcher pressure washer 4000 psi 3.6GPM with Honda GX 390 ,,,,I have used 3 times so far and I forgot to drain petrol before store in its shed,,,,,basically it is new
Yesterday when I tried to clean the carburetor I realized it is badly covered with gum and I used a carburetor cleaner ,,,,it cleaned it but not completely clean
Code
https://imgur.com/a/96J4x8m
I don't have ultrasonic machine and I prefer not to use a harsh chemical ,,,,,what other suggestions can be considered ?
Thx
I've seen it suggested that in lieu of an ultrasonic cleaner you can simmer your parts in a pot on the stove top.
You don't want it boiling just simmering.
You'll want to remove any plastic and rubber o rings. Just put metal components in.
You'll want to use a gentle cleaner like dish washing liquid or something that won't eat the aluminium.
You'll probably want to do it outside if you can and you'll probably also want to avoid using the pot again for food.
Having said that I also don't have an ultrasonic cleaner so I normally just disassemble the carb fully (remove emulsion tubes and jets etc) and give it a going over with carb or brake cleaner and give it a scrub with a brass wire brush for the external parts and use a spray gun cleaning kit for the jets and tube and internal passages.
If it's really gummy (like a thick gel) I find acetone makes short work of it.
If that fails, I usually just replace the carb.
Thx looktall for the instructions and informative details,,,,,I have few questions :
1-
Brake cleaner would it clean as well ,,,,,?
2-
Is there a good brand one you recommend ? I need to have it in my repair kit
3-
Do you think ultrasonic would be a most effective thing to clean without affecting the rubber seal ?
Brake cleaner is similar to carb cleaner but uses slightly different chemicals.
It works well enough that I'll use it for carbs if I don't have carb cleaner and I use it as a good general parts cleaner.
I use this spray gun cleaning kit.
https://www.bunnings.com.au/craftright-17-piece-spray-gun-cleaning-kit_p6290484
You should really remove orings and other seals when cleaning a carb.
Carb cleaner and brake cleaner can both cause damage to them although some cleaners are less aggressive and can be less likely to damage them.
And ultrasonic cleaners can also cause damage to orings either through swelling or straight up disintegration of old worn seals.
Sometimes there's a bit of trial and error to find a good cleaner that doesn't damage plastics and rubber.
Brake cleaner is similar to carb cleaner but uses slightly different chemicals.It works well enough that I'll use it for carbs if I don't have carb cleaner and I use it as a good general parts cleaner.
Noted
Will consider that
Agree
Regards
With great care I have used cellulose thinners but not sure about plastic or rubber parts.
Does it run now , or only on choke or hunts badly? I may be able to point you in the direction of the cause.
Do you have petrol with ethanol in it? It is a right nightmare here- we only recommend super unleaded ( less ethanol ) and drain carb every time you use it , and drain tank if not to be used for weeks or more.
Regards
Thx midget98 I didn't try it yet I will update you
Regards
18,241 Registered Users
Topics12,778
Posts106,882
Members18,242
