1,755
2,015
Posts: 4,291 Likes: 4
Hi Blumbly, Unfortunately I haven't got much knowledge of the Scott Bonnar rotaries, but I am doing some research on your machine for you, as we speak. Taking the Model 45 Scotty as being introduced in 1968, one would presume if the model numbers were applied sequentially, that the Model 49 was introduced late 60's to early 70's. It is in fantastic condition for its age, and would restore beautifully.  on a great score Jeffery! PS. I will post any information as it comes to hand!
Wow thanks guys that helps a bit.I think it shows that my air filter box in not quite the right one.It would be good to know how long that model ran for.
Posts: 1,819 Likes: 6
I had one of those but the alloy was so rotted that the only place for it was mower heaven.
Don't suppose you kept the air cleaner? As I don't think it has the right one on it.
The engine had no cowl or anything on it either. It was all corroded that bad that it could not be pulled apart.
Blumbly, The Scott Bonnar logo in my previous post came to me originally from "willingworker" (lol I didnt know he was a member here). He gave me heaps of help with my "Centenary" model Scott Bonnar. He would be the best bet to go to for decals of various SB models too. Stationary
![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2011/08/full-2055-2974-dsc03497.jpg) Is this the type of air filter housing your after?
Posts: 2,738 Likes: 6
Wow, she is a pretty one, I should be able to help you get the carby done if you like!
Cheers Ty
Not sure Joe.I don't know if it is the correct air cleaner.Stationary wow that is a good decal there.Yes I guess at some point I will need to get some sort of copy done.
I believe the air filter in the middle might be what you are looking for there Jeffery, I will see what i can do to verify that!
Cheers Ty
Well I will have a look tomorrow,but I think that is very similar to what's on it.It just doesn't really match the one in the diagram above.
I have seen that Air filter before, Let me do some digging, and see if i cant help you out there.
It is a beautifull machine, and I'm sure if anyone can get it looking like that add again, It's you mate.
Are you going to take the base you your welders to get the hole patched up?
Cheers Ty
Yeah maybe.I think I may have a little plan first.If it works then I may not.After all I won't be mowing lawns with it.
OH? What are you thinking you will do for this one.
There is another cotty with the same base somwhere ion ebay at the moment, it's in a lot of 3.
Cheers Ty
Don't suppose you know the eBay number?
HERE it is. I just realised however, that there apears to be a repair in the exact same place, and a chip in the front.
Cheers Ty
That looks more like a four stroke.
It is, but the base is the same, the Villiers engine is mounted using a removable adaption plate, and you sould simply move it across to this base, however, sadly, I dont know if this base actually is any better, or more repairable.
Cheers Ty
I'm sure it is worse than what I have.Just drained the tank and oh my god.It is brown and smells like turps.I don't even think it was petrol any time of it's life.
If that is the case, I would really recomments Giving the carby a good going over, get all the muck right out of it.
Cheers Ty
Well I really don't think any would have gone to the carby as tap was turned off,and I checked it doesn't seep through it.I will check but I feel it will be OK.Hopefully I will get it going tomorrow.
Even though it is often recommended in the manual, many people do not turn it off by closing the fuel tap, so there is still a good chance the carby was never run dry.
I would have a look in the float bowl first mate, could be all gunked up in there.
Cheers Ty
I'm referring to fuel that was left in the fuel bowl, last time it was run.
It can turn into a nice muck that jams the float!
Heck, I've had it happen in carby's on machines that arrived here with empty tanks.
Cheers Ty
Yes I know but I do get the feeling that this one has been fairly well looked after.
That's good then, I guess either way you will find out sooner or later.
I'm very curios to see this restore as it goes along, there is just something so intriguing about this machine!
Cheers Ty
Tell me about it.It has broken my Victa rule.
I have noticed that, do you think it will start a trend?
I must say, the engine on the four stroke model on ebay has me curios, I might keep an eye on that one!!
Cheers Ty
No not at all.I'm still sticking to my rule.This is just the one exception.
Members18,141
