1 members (MarkusB), 3,906 guests, and 2,113 robots.
#2559 04/04/04 09:16 PM
Hi all
I am currently in the middle of restoring a Victa Comact Lightweight model V192, and I beleive it was manufactured between 1977-80. This model has an 85cc 2-stroke engine showing the number:- 488 508WJ 243.
Bruce has kindly forwarded me a parts list and I am desperately trying to locate Crankshaft Bearings Oil Seals and several other minor parts.
I have tried almost every parts supplier here in the U.K that I can find (including Bartrams)but I am informed that Victa U.K ceased suppling these parts a good few years ago so my only option now is to import them if they are still available.
The Parts I require are as follows:-
BEARING ASSY EN71909A (lower crankshaft bearing and cover)
BEARING HA25325A (upper crankshaft bearing)
SEAL HA25337A (crankshaft oilseals 2 needed)
TAP HA25419A (fuel tap)
GASKET EN71430A
COVER CR03422A (carby ignition cut out part)
PLUG CR03413A (also carby ignition cut out part)
DRUM ST12353A (starter cup or drum located on top of flywheel)
PIN ST12537A (for recoil starter)
ROLLER ST12538A (also for recoil starter)
BLADE SET CA093065.
As I mentioned earlier, I am determined to get this mower back up and running again but I seem to have run into a dead end here and you guys are my only hope so any pointers or information that you can give me would be very gratefully received.
Many Thanks in advance.
Alan.
Alan,
I will be getting back to you this week regarding the parts. I have some in stock but am having some trouble locating the rest.
Bruce [Linked Image]
Thanks Bruce.
Hi Bruce
Do you have any news yet of the parts?
Thanks.
Alan.
Alan,
Sorry for the delay but it is taking a bit longer than I thought. I will e-mail you a list of parts that I have available tomorrow.
Hi Bruce
Sorry to bug you but could you let me know what parts you do have available at the moment?
Alan
Alan,
I have listed what parts that I can get so far(Below). I am still trying to locate seals.
<font face="verdana,arial,helvetica" size="2">Originally posted by Alan:
Hi all
BEARING ASSY EN71909A (lower crankshaft bearing and cover)Not Available
BEARING HA25325A (upper crankshaft bearing)In Stock
SEAL HA25337A (crankshaft oilseals 2 needed)Looking for
TAP HA25419A (fuel tap)In Stock
GASKET EN71430A No Longer available
COVER CR03422A (carby ignition cut out part) In Stock
PLUG CR03413A (also carby ignition cut out part) In Stock
DRUM ST12353A (starter cup or drum located on top of flywheel) In Stock
PIN ST12537A (for recoil starter) 2nd Hand Only
ROLLER ST12538A (also for recoil starter) 2nd Hand Only
BLADE SET CA093065. In Stock
Alan.
</font>
[This message has been edited by Bruce (edited 12-05-2004).]
18,146 Registered Users
Members18,147
