7,275
1,772
I have reassembled the motor and carb on my vista 2 stroke engine. It has a black plastic carb with the spark plug on the left hand side - the only writing on the machine is 'Victa Sports' with 'Power Torque Engine' on the plastic engine cover. I have tried pull starting, I have good spark but it doesn't fire. When I remove the spark plug it is wet with fuel.... maybe it is flooding?? When I reassembled the carb did I need to rotate the poppit valve into a certain position - it seemed to me it didn't matter. Would that be an issue? In addition I wasn't sure which way up the black rubber diaphram should have gone back in but it did only seemed to go on one way to have a good fit when the back cover of the carb snapped back on. I would appreciate any things to correct or look for in getting this machine going again.
Graham
Posts: 5,450 Likes: 36
Graham, Information has been sent to you regarding the carby. Also check your fuel, because if it is over 8 weeks old it will not fire and cause the same problem especially if the mower is old. Regards, Bruce ![[Linked Image]](https://www.outdoorking-forum.com.au/board/biggrin.gif)
Bruce,
Thanks for sending the info. I don't usually have any problem opening and viewing Adobe PDF files, however I could not open the one you sent. I will try some alternatives.... but if you could try sending again? Yes, the fuel was over 8 weeks old.... so will get some fresh fuel/oil and see how we go.
Cheers, Graham
Graham, Did you get the information that I sent you? Also how did the changing of the fuel go? Regards, Bruce ![[Linked Image]](https://www.outdoorking-forum.com.au/board/biggrin.gif)
Posts106,871
Members18,214
