7,152
994
Hi All, Have a Silver Streak 18" cut (steel base) with powertorque V35 engine pac and a self propelled Mustang 20 20"cut (alloy base) with powertorque V50 engine pac and would like to fit a 4 blade plate to them. They both have the "oval" shaped, 2 blade, late Victa disk (OEM No. CA09335K or CA09320K)on them. I see the online store has a 4 blade, Victa disk non genuine (OEM No.CA09320K), that suites both 18" & 20" cuts taking the 18" or 20" cutting blades and bolts. Is it possible, and what is involved in fitting the round 4 blade disc to these mowers? Seems straight forward to me....R&R, or am I wrong? Is there a mulching kit, plug etc. available for either or both these models, if so which 4 blade disk would be required for the conversion to them? All advice appreciated, TIA LS
Hi Lawn Slave, and a warm welcome to the forum.  We all like to learn new things and tinker here! Re your questions, as a Scott Bonnar man, I can't give you much advice on the blade switch, but I'm hoping Joe Carroll, our resident Victa guru, will jump in here with some thoughts. If not Bruce (site administrator) may be able to help you. Once again Lawn Slave,
Thanks Darryl, shall await for a response.  P.S.
Posts: 5,451 Likes: 36
Hi All, Have a Silver Streak 18" cut (steel base) with powertorque V35 engine pac and a self propelled Mustang 20 20"cut (alloy base) with powertorque V50 engine pac and would like to fit a 4 blade plate to them. They both have the "oval" shaped, 2 blade, late Victa disk (OEM No. CA09335K or CA09320K)on them. I see the online store has a 4 blade, Victa disk non genuine (OEM No.CA09320K), that suites both 18" & 20" cuts taking the 18" or 20" cutting blades and bolts. Is it possible, and what is involved in fitting the round 4 blade disc to these mowers? Seems straight forward to me....R&R, or am I wrong? Is there a mulching kit, plug etc. available for either or both these models, if so which 4 blade disk would be required for the conversion to them? All advice appreciated, TIA LS The 4 blade holder (generic) is no longer available but you could use the genuine one CA09444G which is still available, as to the mulching plug they are not available for your models.
I would also reccomend the mulching disc as they are genuine and I find even without the mulching plug and the the catcher on they give the best cut of all the 4 blade discs.
Topics12,777
Posts106,881
Members18,233
