2 members (Red Rum, looktall), 8,011 guests, and 434 robots.
#21118 09/01/11 04:46 AM
Hi, I'm trying to work out why my mower won't start. it has always been a great mower. It is a Victa commander 1996, 160cc. The original problem was a carby cable popping out. Now it won't start even with fuel in the chamber. I think the carby is working OK. I tested for spark and yes, there was some but I can't tell if it was enough so I went and had a look at the kill wire. There are two wires that come out of the engine and when I test with a multimeter they show zero resistance to each other and both show zero resistance to the engine frame. Does this mean the coil is shorted to earth?
I'm guessing that Victa 2 stroke has a G4 plastic carburetor. If so it has two wires coming out of the carburetor. One of them goes to earth, so resistance should be zero. The other one goes to the ignition module. Grounding that one kills the ignition. I don't know what its resistance to earth should be: if it is an electronic ignition you are probably measuring the backwards resistance of a semiconductor.
Do you get a steady stream of blue sparks across the spark plug when you pull the starter (spark plug removed, body grounded to cylinder head)? If you do, the ignition is not your primary problem. If not, check the coil to flywheel clearance (should be 0.012" or a visiting card thickness), check that the coil's ground wire is clean and making contact with the engine, disconnect the kill wire from the carburetor, and repeat the spark test. If it still fails the test, you need a replacement ignition module.
Thank you grumpy; I have actually replaced the original mechanism with a toggle switch years ago. I think the spark is OK now and the switch is working too. The problem must be with fuel. I'm going to start a new thread about the carby and I know you don't like plastic carbs.
Joe Carroll is my guru on plastic carburetors, sparker. I'll close this thread.
18,214 Registered Users
Posts106,871
Members18,215
