2 members (Bruce, Buckets), 10,972 guests, and 1,471 robots.
G'day,
I have a Kubota D210 brushcutter, and I want to cut through some reeds on the edge of the river bank that are starting to take over, so was thinking if I would be able to get a blade attachment for it as the line just isn't up to the task. I realise that I need to be abit more carefull with a blade than the line.
So couple of questions:
Can a blade fit?
What type should I get ie is plastic ones safer but will they do the job?
Thanks,
Chris.
Hi Chris,
Providing that the brushcutter is a straight shaft unit then a blade will fit but if it is a bent shaft you will need to use a plastic blade. cheers2
Thanks Bruce,
Yes it is a straight shaft with the nuckle(?) at the bottom.
How tough are the plastic blades, anyway?
Do you reckon they would cut through the reeds?
Lastly, are they a universal fit or do I need a specific one for the Kubota?
Thanks,
Chris.
Chris E,
Usually with most brushcutters they have a step (approx 25mm dia) washer that the blade centre fits onto. I would suggest a saw type blade in order to cut the reeds with. cheers2
Thanks Bruce.
Does that mean a normal circular saw blade may fit or is there a specific blade for the job?
Thanks,
Chris.
I ended up being given a plastic housing that has 3 platics swing out blades that has metal teeth on them which is made to suit brush cutters. Worked perfectly. Might need to try and track down new blades eventually.
18,237 Registered Users
Topics12,778
Posts106,882
Members18,238
