1 members (Murpha),
1,811
704
Posts: 6,362 Likes: 10
Hi Jay, this seem to be good advice as I've seen this method used, with no disasterous results, providing it is done with care, obviously!!
Posts: 5,395 Likes: 35
Hi all, To get the boss of a Victa 2 stroke including powertorque I have always heated the boss, then locked the boss in a vice and hit it with a hammer until the engine slipped free! Always worked a treat for me wit no residual damage Regards jay The only thing that you have to be careful with is not to damage the seal (as it is rubber) and if heated too much you will have issues with air leaks.
But then again change the seals while its apart and buy some insurance for the machines lifespan
Yes Joe I agree with you that if you heat up the boss you should replace the seal.
Hi all, I do agree that you need to be careful about the seals, but I only ever heat engine parts with a kero blow torch anyway to avoid damage (they donοΏ½t get all that hot!). I personally have only really removed the boss to replace the seals or dismantle the lower end-witch I usually replace the seal anyway. Does anyone have any idea of the working temp of there seal as I would assume it would be pretty high anyway. Thanks for your help Regards jay
Jay, That's a good question about the working temp of the seal and maybe someone has the answer. If I get a chance I will check with my supplier and see if they can put some light onto the matter. I normally use OXY acetylene to heat stuff as a last resort and when you use that you need to replace seals because of the extreme heat generated.
Topics13,058
Posts107,236
Members17,806
