0 members (), 4,092 guests, and 303 robots.
by Bumps - 19/03/26 11:57 AM
Mower wheel ID.
Shout Box
by geobee - 14/03/26 08:36 PM
Victa Super 24/600
by Doug - 07/03/26 07:07 PM
Eaton Model 6/7
by Bumps - 01/04/26 05:37 PM
Mower wheel ID.
Eaton Model 6/7
by Bruce - 20/03/26 09:50 AM
by Bruce - 19/03/26 11:52 AM
Shout Box
by Bruce - 16/03/26 08:10 AM
Early Morrison rotary mower
mowernut #14045 30/09/09 04:58 AM
Hi Jay, this seem to be good advice as I've seen this method used, with no disasterous results, providing it is done with care, obviously!! grin
mowernut #14050 30/09/09 07:48 AM
Originally Posted by mowernut
To get the boss of a Victa 2 stroke including powertorque I have always heated the boss, then locked the boss in a vice and hit it with a hammer until the engine slipped free!
Always worked a treat for me wit no residual damage
Regards jay
The only thing that you have to be careful with is not to damage the seal (as it is rubber) and if heated too much you will have issues with air leaks. cheers2
Bruce #14052 30/09/09 10:59 AM
But then again change the seals while its apart and buy some insurance for the machines lifespan smile
#14054 30/09/09 05:13 PM
Yes Joe I agree with you that if you heat up the boss you should replace the seal. cheers2
Bruce #14056 30/09/09 08:03 PM
I do agree that you need to be careful about the seals, but I only ever heat engine parts with a kero blow torch anyway to avoid damage (they don�t get all that hot!). I personally have only really removed the boss to replace the seals or dismantle the lower end-witch I usually replace the seal anyway.
Does anyone have any idea of the working temp of there seal as I would assume it would be pretty high anyway.
Thanks for your help
Regards jay
mowernut #14073 02/10/09 12:40 PM
Jay,
That's a good question about the working temp of the seal and maybe someone has the answer. If I get a chance I will check with my supplier and see if they can put some light onto the matter.
I normally use OXY acetylene to heat stuff as a last resort and when you use that you need to replace seals because of the extreme heat generated. cheers2
Pazzaboy, mgman, Drennie, RobNich, JLAU
17,905 Registered Users
Topics13,076
Posts107,348
Members17,905
PHP: 8.3.30 Page Time: 0.045s Queries: 27 (0.040s) Memory: 0.6523 MB (Peak: 0.6897 MB) Data Comp: Zlib Server Time: 2026-04-04 01:49:43 UTC
