2 members (Gizmo, Buckets), 557 guests, and 1,779 robots.
Masport Shitemaster 720 blade
#13390 01/09/09 04:13 PM
Hi bruce and all
How meny ohms is a victa coil ment to have for testing
i get on 1k setting 550 - 600Ω is this right?
Am i using the right setting?
How to test a condenser?
Victa.ducky,
I use a coil and condenser tester which cost around $600-$800. I have never used an ohms tester for checking coils as it is not really accurate for a coil under load. cheers2
Bruce #13404 02/09/09 05:22 AM
A common failure mode for coils is insulation breakdown in the secondary winding. This results in little or no spark, but no real change in resistance. A very high resistance reading can tell you that a coil has burned out, but a normal one doesn't tell you that it is OK. I don't know of a worthwhile way to check capacitors other than on a tester or by substituting a known good one. If there is no spark and you have checked the obvious things (kill switch contact has become grounded, broken or disconnected wires, bad spark plug), my solution has been to take the ignition unit to someone who has a proper tester - usually the friendly local mower man. Of course proper enthusiasts always seem to have spare ignition units, which is a quicker and cheaper way to see if that is the problem.
MVC Offline
[video]
[/video]
bruce would doing this with a mower coil work as well
Victa.ducky
I would go with the video of MVC has supplied to check. cheers2
18,062 Registered Users
Topics12,746
Posts106,765
Members18,063
