0 members (), 6,256 guests, and 453 robots.
Hi, can anyone please let me have a user manual for a Super Airstream IV ?.
It's the version without the primer bulb and I'm not sure what the procedure for starting it.
Much obliged,
Colin.
Colin,
Usually with the starting procedure you prime the plastic bulb about six times (or until it has pressure while priming), then turn the switch to the on position and then place the choke lever in the choke position.
Once it sounds like it will start (pop) you then put the choke lever in between choke and open then it should start and once running you then put the choke lever into the open position. cheers2
Thanks Bruce for the reply, problem is this thing doesn't have a primer bulb, unless they've hidden it just to frustrate dopes like me.
I've found the repair manual for it and that doesn't mention a bulb anywhere.
I shall persevere and probably have a coronary in the process.
Thanks again for your help.
Colin.
18,229 Registered Users
Topics12,777
Posts106,880
Members18,230
