1 members (Bruce), 7,690 guests, and 137 robots.
Hi.
I have an around 1990s Rover Ranger Autodrive with the 76 cm single spindle deck.
My source of frustration is figuring out how to engage the deck spindle brake because it works in reverse of its desired function. That is on when the deck is engaged and off when it isn't.
I have the parts manual, I have the owners manual and tried adjusting the various rods in combination in many ways.
Is there anybody who has experience with this problem and how to solve this dilemma?
I have attached a picture of the affected area as per the parts diagram.
[img]https://www.outdoorking-forum.com.au/forum/ubbthreads.php/ubb/download/Number/23452/filename/[/img]
As a last resort I am considering drilling another hole in the brake pivot (17) to change the action of the brake plate (18) with the hope that I get it right the first time.
Cheers and keep smiling it hides what you are thinking.
Rusty Cuts
Follow up, the parts manual appears to be listed here as 53177_160.pdf pages 11 and 12.
Also on another post regarding an xc by member Yappie beginning 08/08/12 I believe I observed a tension spring connected between the chassis bolt tab and the deck brake assembly, picture number 4, 5 and 6 of the xc .
Could this be a home made alteration, it appears that the spring is a standard deck height adjuster spring.
Possibly this alters the pivot mechanics, thinking the measure twice cut once philosophy.
Hi Rusty Cuts
General Troubleshooting Guide
This is a common issue on the single‑spindle deck.
Do NOT drill new holes — the factory geometry works when everything is assembled correctly.
Below are the checks that normally identify the problem (just a general guide) .
🔧 Most Common Causes
Brake return spring in the wrong position
If the spring is hooked to the wrong tab/hole, the brake plate moves the wrong way.
Rod connected to the wrong hole on the bellcrank
The Autodrive lever has multiple holes. The wrong one reverses the action.
Brake pivot (17) installed 180° backwards
It can physically bolt on flipped. When reversed, the brake works backwards.
Brake plate (18) installed upside‑down
It looks symmetrical but isn’t. Upside‑down = reversed action.
Cable clamp positioned too far forward/back
This shifts the neutral point and makes the brake apply at the wrong time.
Correct Brake Behaviour
Deck disengaged:
Brake plate presses against the pulley
Belt is slack
Spindle stops quickly
Deck engaged:
Brake plate pulls away from the pulley
Belt tightens
Spindle spins freely
If yours does the opposite, the linkage geometry is wrong.
Fix Sequence (Before Modifying Anything)
Disconnect the deck‑engage rod
Let the brake arm sit in its natural rest position.
Check brake arm orientation
The brake pad must sit behind the pulley.
Check spring location
The spring must pull the brake on when disengaged.
Reconnect rod to the outermost bellcrank hole
This ensures the rod pulls the brake off when engaged.
Adjust cable tension last
Cable tension fine‑tunes the action — it should not reverse it.
❌ Why Drilling New Holes Is a Last Resort
Drilling a new hole in pivot (17) can cause:
Brake too weak → blade won’t stop
Brake too strong → brake drags
Only one chance to get the angle right
Almost never needed — the factory setup works when assembled correctly
Wrong spring position
Wrong rod hole
Brake pivot flipped
Brake plate upside‑down
One of those four almost always fixes the reverse‑acting brake.
Hi Max.
Thankyou for the detailed explanation.
Currently there isn't a spring to the front from the deck brake lever with brake pad, so that's an item on the list. Planning to run it from the same rod as which has the tab for the adjustment lever to the deck brake, with the idea the the spring act like a tendon on the ankle.
Hoping a deck height spring from a push mower covers that
Will play with the deck engagement lever by moving it to a different hole.
One thing, the deck brake is in the centre of the deck, can't seem to locate a hole for the spring to seat into, that's still to be worked on will find out when I pull it out.
Anyway I will keep everyone updated, hopefully I remember to take some happy snaps.
18,173 Registered Users
Posts106,820
Members18,174
