0 members (), 2,779 guests, and 1,681 robots.
Have above generator in quite good condition apart from badly rusted fuel tank and damaged needle valve. Needle valve was firmly stuck with a lot of grunge and I couldn't take off the float to get to the needle valve without wrecking the wire which the float pulls on to drop the needle down when the bowl is filling.
All the passages are full of gooey rust and crud. It's a 2012 model gennie and previous owner said it was only started twice and stored all these years without draining the tank.
Anyway might be able to get away with just a new needle valve and a bit of micro-cleaning but suspect if a replacment carb can be found it would be better option.Of course there's no numbers anywhere to be seen except "4" inside the float bowl.
Distance between centres of mounting bolt holes is 42.5 mm.
Photos attached, hoping someone can tell me it's a XYZhangWang and is identical to a GXYZ Honda carb.
My main concern it has an automatic rpm system and would be great to not have to rejig that to suit replacement carb with a slightly different throttle lever.
Hi MM,
There is a carby doctor site you could ask them if no one here recognizes that carby carbydoctor.com.au
I usually just find a carby that is close enough and modify the linkage.
Max
Thanks Max,
That first one looks close enough. I have cobbled up non-original carbs onto many cars, motorbikes, mowers, mulchers - just a matter of the right spacing between the mounting bolt holes, the right inlet bore and getting the jets right but with a 2000W genie I'm wanting to have the auto governing system working spot on as it will be mostly running unattended.
Dunno if you ever saw in my Introduction posts to ODK what abominations I do with my mower carb controls, usually getting rid of any governance altogether and converting them to manual -
https://outdoorking-forum.com.au/fo...re-than-one-mower-or-two.html#Post115811
This time I need a bit of finesse:-)
Interesting post MM and the link to all the mowers ,I've had multiples of all of those mowers you showed and still have too many mowers now.
I had another quick look for a carby and this one below was about the closest but throttle butterfly is working the wrong way.
Sometimes you need to change wording for better search results ,for some reason searching (pump carb industrial power tools) worked better.
The old days you just went to a mower shop with the old carby but these days they say we don't stock parts and order in bulk for free postage
and can't tell you when they will order the part or when you will get the part ,that's if they want to help but now just say they don't stock the part
you are after.
Carb Carburetor For Kohler Command Pro CS6 6HP gasoline engine 7NJ1410110-00
had to find it eventually.
Don't you just love these fly by night Chinese OEMs. Pop up make a ship load of equipment and then disappear leaving us that repair equipment to look miracle workers at times.
And this is a world wide problem too. We here have the same problem with manufactured in China and Far East countries. No wonder our landfills is so full thing that otherwise be repairable if only the parts were available.
Now that part number is a Yamaha 7NJ-14101-10-00 superseded to 7CN-E4101-11-00.
EF1600X 7NH2 EF2600X 7NJ2 YG2600X 7NP1 GENERATOR 1996
EF1600A 7RR2 EF2400A 7RS2 GENERATOR 1997
EF2600A 7UU2 GENERATOR 1999
YP20/30GX 1996
YP20TA Q9C4 YP30TA Q9C5 YP40TA Q9C6
So this might help looking any of the other engine parts.
Now here is a good question which CS6 Spec does this fits as there are different carburetor setups on some of them? With the correct I could find the Kohler part number.
Hallelujah ! The generator is now running perfectly without me needing to buy any new parts. Managed to clean out all the passages in the carbie, made a few gaskets, got the majority of the crud out of the fuel tank and put a filter in the fuel pipe to catch whatever comes through in future.
Thank you to Max and AVB for finding a possible replacement carb for me. The one Max suggested looked good enough but AVB's one is identical to what I have.
Between Max, AVB and Norm I reckon any problem with mechanical devices could be solved. I am very grateful to be able to ask questions and receive such excellent advice on ODK
7 8 9 10 11 12 13
14 15 16 17 18 19 20
21 22 23 24 25 26 27
28 29 30
Lowes Hire NZ, NumbedNuts92, StewFuchs, Gib, auProspector
18,095 Registered Users
Topics12,750
Posts106,783
Members18,096
