1 members (Bruce), 3,517 guests, and 446 robots.
by Bruce - 28/11/26 12:52 PM
Hi guys, I bought a Stockman,25K96,0774 13 hp Honda a few weeks ago,It hadn't run in many years I gathered. I'm just running the spanners over it and will use it this wet season as the push has turned into a 2 day affair now.Changed the engine oil and it fired up and is running well,took it for a run up the driveway where upon it shuddered and clunked every now and then,I thought it may have been the drive chain rusted or the tensioner as something was grabbing and releasing, today I took that wheel off,chain doesn't have any tight spots so I'm thinking something in the diff is off,maybe no lube is present.So thought I'd ask here before opening that up.There's a valve release? which comes out through the rim,which I'm thinking may release oil as i can't see any plugs for topping up oil or draining it.Nothing came out.So is this a straight forward job?Any special tools needed.Hours on gauge is 537 and lights and the rest of the mower looks to be quite ok.
regards
Colin
Hi Colin, long time no hear, don't know anything about your Stockman tranny but I do know a bit about the old Enfields
Hello there Norm,well well the circles have turned,it took me a minute to think who could this be,then it came back and i remember you and Ant got into the mowers..I've just gone through the parts book and it looks like this pin on the end of the axle is a diff lock so will have a look in the morning.Hey the old enfields are out of favor these days,mine are all parked up.
Hi Colin,
Yep I haven't ridden my old Interceptor for probably 5 years now, Got home from a meeting one night and it took me a long time to be able to get off it. I figured then it was probably a good idea for me to stop riding
And yes I am still fixing Ants mowers as he still has little knowledge of anything mechanical. If you remember he started the Club all those years ago because he wanted somebody to fix his Enfield. Haven't fixed any of his bikes lately, but he always has a mower here needing repairs
Went around to the local Cox agent,he hadn't seen a Cox with that type of diff lock,he said that was only fitted to Greenfields(he had a couple of those new also along with 8 Cox's). It's a sealed unit.With that I got home and played around with that pin and when it's out wheel freely spun so probably no problem and I'll never have a need for diff lock as block is dead flat.
Hi Colin,
Good to hear, I have only had one Greenie here that was fitted with a diff lock and I only clicked it in and out to make sure it was working. With the diff lock disengaged it makes turning them so much easier. Sounds like somebody has scavenged it from a Greenie. I have often wondered how the conversion would go on an earlier Greenie I built for Sheriff in the Club because he is having trouble turning his with both rear wheels driving. Anyway good to hear your drive is now working
I've included a pic of the diff,it appears it was optional back then,chain is worn out anyone known what size it is?how many links?Has anyone taken this diff apart,I want to check it for lube as it appears to have seals that are available in the parts book,colin
Just picked up the correct chain,only $45 so that was about half i was expecting.
Turns out it was the incorrect one.to narrow so back it went.No help here,can i delete ?
G'day leslloyd,
Please don't contemplate deleting your post, actually, I don't think you can... although I could be wrong on that admission .
Having said that, I'm sure that there will be somebody here that will be able to assist you with your predicament...
mice_elf
Well see if this one is closer.
#40 Roller Chain 1/2" x 5/16" 43 drive links. The other chain was probably a 3/16" version for the non differential models.
Stockman 231901
or
Stockman 231901 chain
IPL Manual Download
22-25I3-25E94-25K94-25H94-25C95-25K95-25K96.pdf
Take with a grain of salt as I am a few skips and a hop from the there.
Hi Colin,
I'm surprised you got the wrong chain, I know you have been dealing with chains for a very long time (Only joking)
hi all,yes indeed 231901 425 1/2"x5/16" roller .312" ,is the correct chain,incorrect is 428 1/2"x5/16" roller -335" ,took some sorting as the chains passed to me over the counter were packed in cardboard packets and I only found they wouldn't fit after getting home and unpacking,and that was the salesman and spare parts guy saying yes yes that's the correct chain,I only asked on here for type and links as the old chain was caked in grease and i didn't want to slam that on there bench for them to work out.So the first chain i kept afterall and it went on the steering,turns out the rear chain was a 428,which was wrong anyway,425 is correct.They have now discovered there is a model with a differential after all,well before there time I expect,anyway the the Honda is purring like a kitten,belts tightened and clutch adjusted she's a beauty smile
Thanks AVB!you got it right.
Final post here to show Cox differential on the 25K96 model,circa 1996-8.Took her apart as I wasn't sure if it was lubed up and there's no way of telling,there was HT grease there but the gears teeth were dry so topped it off with Veedol semi liquid grease.Everything looked good in there,2 bushes,one bronze and one small sealed bearing,nice solid unit.So I can rest easy now knowing that's lubed.
18,248 Registered Users
Topics12,780
Posts106,888
Members18,248
