1 members (Gizmo), 848 guests, and 1,061 robots.
#120626 15/01/25 08:30 AM
I have a GCV160 here starts ok on full choke but the slightest attempt to move off choke and it stops. Normally I would just rip the carby off and put it through the ultrasonic but I think there is something else going on. I have checked the valve clearances and they are fine. What concerns me is that when pulling this motor over there is an unusual "choofing" noise coming from the exhaust or maybe head gasket. Any thoughts?
NormK #120632 15/01/25 04:53 PM
Ok mudwasp nest in the muffler
NormK #121905 06/11/25 04:32 PM
Ok I am obviously doing something wrong. I have put a number of Honda carbies and Briggs as well through the ultrasonic cleaner, clean the emulsion tube, main jet and blow air through the jet on the top of the carby. Some carbies are fine after this but I still get a percentage of these carbs that usually still hunt. I know if I put a new carb on it it will work fine, I am just curious as to why these carbs do this. Is there something I am missing?
NormK #121907 06/11/25 08:54 PM
You could use a cheap can of brake cleaner ,Boston 300g Aerosol Brake Cleaner $7.50 ,you may need to drill the cleaner nozzle
and push in the small plastic tube from a WD40 can , then spray that into all the orifices to make sure they are clean.
Sometimes I need to use fuse wire to clean a jet back to original size and sometimes you need to push an oxy tip cleaner through
if a pilot jet etc won't unblock after cleaning.
I have heard some people say the only thing after cleaning the carby that stopped the surging was to increase the jet size.
Most of the time the surging is the blocked jet on top (pilot jet)
I've been meaning to try Acetone overnight but as we know What NOT to Soak
Rubber parts (gaskets, O-rings, seals) – acetone will swell, crack, or dissolve them.
Plastic pieces (floats, choke housings, etc.) – may soften or melt.
Painted surfaces – acetone removes paint instantly.
[video:youtube]
[/video]
I don't spend much time on them if I clean a carby and it still hunts I just clean another carby and it fixes the problem.
NormK #121910 07/11/25 07:37 AM
Yes Max, I do all the above things every time I put them through the cleaner, some work some don't, just thought I must have been missing something
NormK #121911 07/11/25 08:24 AM
If you are sure every internal passage is clean then the carby must be damaged Norm.
Fuel Passage Corrosion or Micro Cracks
Older carb bodies sometimes get internal corrosion, especially if ethanol fuel sat in them.
This can restrict internal drillings or create an internal leak path between air and fuel galleries.
Ultrasonic cleaning can’t fix that — only replacement will.
the internal passages in the old carb aren’t truly open, even after ultrasonic cleaning.
NormK #121912 07/11/25 08:42 AM
This is what I've seen can happen to old carbs.
How Micro-Cracks Form in a Carburetor
Carburetors are usually made of die-cast aluminum or zinc alloy (pot metal). Over time, several things can create microscopic cracks or porosity in the casting:
⚗️ a. Corrosion from Ethanol Fuel or Water
Ethanol attracts water from the air.
That water, combined with fuel residues, forms acids that attack aluminum or zinc.
The corrosion pits and weakens the metal, especially around thin internal walls and galleries.
With time, these pits can connect, forming tiny internal cracks or porous spots between adjacent fuel and air passages.
🔥 b. Thermal Cycling
Lawn mowers go from cold to hot repeatedly.
The carb body expands and contracts each time, stressing thin casting areas (like around the emulsion tube or fuel well).
This mechanical fatigue can form hairline cracks over years of use.
🔩 c. Overtightening Screws or Fittings
If the fuel inlet fitting or the bowl screws are overtightened, the metal can distort or crack, especially around threaded holes or sealing surfaces.
Once the crack starts, vibration can slowly extend it further into the body.
🧴 d. Manufacturing Porosity
Some carb castings have tiny air bubbles or inclusions left over from the die-casting process.
With time and corrosion, those pores open up and act like tiny leaks.
⚙️ 2. What Micro-Cracks Do to Carb Function
Carbs rely on precise pressure differentials to meter fuel — a few inches of water column is all it takes. Even a microscopic leak can upset this delicate balance.
Here’s how cracks cause trouble:
💨 a. Internal Air Leak
A crack between an air passage and a fuel passage lets air bleed into the fuel stream.
That leans the mixture — so the engine surges or “hunts” as the governor constantly tries to compensate.
⛽ b. Fuel Leakage Between Passages
If a crack connects the main jet well to the float bowl vent or to the atmosphere, fuel pressure can’t build properly.
The carb can’t pull enough fuel up through the emulsion tube → lean running or stalling at throttle transitions.
💧 c. External Fuel Seepage
A visible hairline crack in the casting (often near the bowl threads or inlet) can allow fuel to weep out slowly.
You might see dampness or fuel smell even if it doesn’t drip.
🧭 3. Diagnosing a Suspected Crack or Porosity
You can try a few tests:
Vacuum Test:
Plug all outlets and apply light suction to one circuit (like the idle jet port). If it won’t hold vacuum, there’s an internal leak.
Soapy Water Test:
Fill the carb body with light air pressure (~5 psi) and spray with soapy water. Bubbles = leak.
Fuel Dye Test:
Fill with dyed fuel (like 2-stroke mix) and watch under bright light for seepage through the casting.
Magnifying Glass / UV Light:
Sometimes cracks show up as faint lines or stains along cast ribs when viewed under UV or strong light.
🧰 4. What To Do if a Crack Exists
Unfortunately, there’s no reliable permanent repair for an internal micro-crack in a carb body. Epoxy or sealant might work briefly, but fuel, heat, and vibration eventually break it down.
So, once confirmed:
Replacement is the only dependable fix.
NormK #121913 07/11/25 02:53 PM
Thanks for going to all that trouble Max. but it might have been easier for you to just say throw it out
NormK #121919 10/11/25 05:14 PM
I could have but I just write answers so anyone that reads the thread can understand the why part.
As we know.
The ultrasonic cleaner should be able to clean your mower carb well enough on its own but If ultrasonic cleaning doesn’t get all the way into the corroded areas, a combo of mechanical cleaning and chemical treatments may work.
It can sometimes be a bit of a judgment call whether to keep cleaning it or swap out the part
NormK #121920 10/11/25 06:16 PM
Yes I know and thanks anyway. Interesting thing was I put a new carb on it today and it is doing exactly the same, so now I'm not sure if the carby was the problem
NormK #121921 10/11/25 07:01 PM
I guess you will need to look further into the motor now Norm like checking for tight valve clearances if you haven't
already spent too much time on this one and just move on to another motor.
NormK #121922 11/11/25 07:22 AM
Yes Max, exactly, I have wasted way too much time on this one already
Lowes Hire NZ, NumbedNuts92, StewFuchs, Gib, auProspector
18,095 Registered Users
Topics12,750
Posts106,782
Members18,095
