1 members (NormK), 1,111 guests, and 165 robots.
by Widget - 03/11/25 08:12 PM
by Ghost - 25/10/25 07:11 AM
Victa 24 engine pulleys
by NormK - 19/10/25 08:49 PM
Re rotomo crankshaft.
Lower Crank Seal - Sprint 35
by NormK - 06/11/25 12:13 PM
by NormK - 05/11/25 08:17 AM
by NormK - 25/10/25 09:57 AM
by NormK - 22/10/25 09:06 PM
The Rover Pro-Cut Chronicles
by DFB - 19/10/25 09:36 PM
#78750 17/10/16 01:52 AM
I assume the lower crank seal can be replaced without any issues from the outside on
a Sprint 35 motor? I guess it will pull out with a self tapper and a slide hammer?
Easy as, there are no issues with this operation.
Thanks Bigted, I couldn't see any problem but thought I would ask, you never know with some of these things
B&S 375 Sprint, weeping from lower crank seal. There's 2 or 3 mm up and down movement of the crank. Same procedure to remove and replace seal?
If you got 2-3 mm you got some serious wear. And I remember correctly this is L-head engine. An normally if this a rubber coated seal they are unually fairly easy to replace.
Hi AVB, how's things going in your world over there, always seems chaotic to us over here?
MM, I wouldn't worry about the end float, lots of them are like that, just push on with it
Calais346, Gregtyu, notausername, Sinti, AndyMowMe
17,653 Registered Users
Topics13,013
Posts106,990
Members17,653
PHP: 8.3.26 Page Time: 0.028s Queries: 27 (0.022s) Memory: 0.6378 MB (Peak: 0.6736 MB) Data Comp: Zlib Server Time: 2025-11-06 03:52:02 UTC
