1 members (Red Rum), 502 guests, and 1,784 robots.
Hi Folks, I have a LTH130 Husqvarna Ride on and I'm replacing the Deck & Drive belts as part of a major service.
The Part Numbers in my Parts Manual are:-
Drive Belt - 532140294
Deck Belt - 532144959
The old belts I have been using for the past 3 or 4 years are Kevlar and the both measure - 87.5" using the belt mark and string method.
According to websites I'm looking for the factory part number replacement belts, they are saying I need:-
A93 - Drive Belt
A81 - Deck Belt
Hence my confusion as to which Kevlar belts to buy.
Any help here is appreciated...
Hi Steve, I have no idea but what pulleys do you have on the deck belts are they "A" section or "B" section I get angry when I see "A" section belts on the cutter deck. They fit "B" section on the cutter deck for a reason Maybe that is the reason for the discrepancy in the lengths. On a mates Greenfied when I changed the belt from "A" to "B" it had to be 100mm longer. Doesn't make sense that your cutter belt would be 100mm shorter
Hi NormK, thanks for your help here.. I have no idea what pully sections I have on the deck. As far as I know they are standard.
I have taken some photos of the Deck Pullys, but I don't know how to include them in a post.
It looks like I have to upload them to somewhere first and then link to them?
There are 2 large pullys - 130mm dia x 15mm belt top width & 2 smaller pullys - 98mm dia x 25mm belt top width if that helps..
Steve
G'day Steve,
I'd probably need engine Hp ,year of mower and the deck cutting width to look up specs.
V-belts are measured based on their length, which can be represented in two ways:
Inside Length (C): This is the measurement of the belt along the inner surface, which is the distance between the two grooves of the pulley. This measurement is typically used for belts that operate over a fixed pulley distance.
Outside Length (L): This is the length measured around the outer surface of the belt. This length can be relevant when the belt is in motion and the outer edges are in contact with the pulleys.
When purchasing or specifying belts, it is important to check the manufacturer's documentation or standard specifications to determine which measurement is being used, as different manufacturers may provide lengths in one form or the other. Always ensure you have the correct measurement based on your specific application to avoid fitting issues.
The last image is inside of the V belt length. When I look up V belt sizes I need engine Hp ,year of mower
and the deck cutting width to find the correct specs.
eg length, Inside Length = 83.75 inches +2×0.5=83.75+1 = 84.75 outer length inches
1 member likes this: Steve_2012
Hi Maxwestern,thanks for your response here and for trying to help me out with this issue.
Here are the details you requested on my Husqvarna LTH130 Ride on:-
Model Number:- LTH130
Serial Number:- 120498D001021
Date of Manufacture:- 4th December 1998
Product Number:- 954-11-00-61
MFG ID Number:- HALTH130B
42" Cutting Deck - 2 blades
Briggs & Stratton 13HP engine
Model Number:- 28R707-1140-E1
Serial Number:- 981114ZE
I have both the Mower Part Numbers & the Engine Part Numbers in PDF Files but, the Ride on Parts Manual has these details on each page:-
REPAIR PARTS - TRACTOR - MODEL NO. LTH130 (HALTH130C), PRODUCT NO. 954 11 00-61
My Mower is earlier than that and has a different MFG ID Number to that HALTH130C - Mine is a HALTH130B?
Steve
Can't see the deck pulleys Steve
G'day Steve,
I looked up the first part number Drive Belt - 532140294 that you had listed and is (1/2" x 82") so is
not close to the 87.5" that you have.
A manual I found has the part number 532161850 V-Belt, Drive and it's Belt Size (Outside dimension): width - 1/2", Length - 85". A83K 4LK850 which is closer to your 87.5 inch.
It is possible for a V-belt that measures 87.5 inches when it is off the machine to measure around 85 inches when it is installed and tensioned. The difference in length can be attributed to several factors:
Tension: When the belt is installed, it is stretched to fit snugly around the pulleys. This tension typically reduces the effective length of the belt by a small amount.
Belt Compression: The interaction between the belt and the pulleys can cause some compression, which can also lead to a decreased measured length when the belt is under tension.
When a V-belt is under tension, it typically becomes a slightly shorter length compared to when it is relaxed or uninstalled.
I'm not sure how you've measured the belt but you could install it and check the difference in length if it's been measured
out of the mower with no tension on the V belt.
On the Deck V belt I get 88 inches which is close to your 87.5 inch length.
Someone may have used a slightly shorter belt on the Deck Belt than they should have .
The manual that I found has 95 in the lower corner so I assume 1995 and hope that is the same for your 1989 mower
as the other specs were the same.
First we got to figure which of the 23-25 LTH130 the OP has as they have different deck configs.
LTH Models
Hi NormK, can you please tell me what happens or what you see when you click on the Image links I posted, that are stored in the Google Photos Links above?
I have little to no idea where I can upload photos that I can share on this Forum or any other Forums.
If you have any ideas I'm happy to check them out.
Steve
NormK & Maxwesten, I have looked into Google Photos and hopefully I have sorted the problem out with Sharing my pictures online with you guys.
Try this link to see the Deck Pully pictures I have taken.
https://photos.app.goo.gl/K9g3xVLyGTCewHWW8
Steve
Hi Steve, bit hard to see but they do look like "A" section pulleys. The way to check is to wrap the old belt on one of the pulleys and see how far the belt sits down in the "V" The correct belt should sit close to flush with the outside edges of the pulley
Hi AVB, My Ride on Mower is a LTH130 with this information on the alloy tag under the seat:-
The Parts Manual I use is as close to that as I can find.
It shows this:- HALTH130C
I have no idea what the exact difference might be between the B and the C?
I have uploaded some photos to Google Photos and the link is above.
Steve
OK NormK, I have added a couple of photos showing the Deck Belt & the Drive Belt sitting in their respective pulleys.
If what you said about where they should sit on the pulleys, both are wrong?
In the past 10 years since getting this rideon as a trade in from a Husqvarna Dealer in Sydney, both sets of belts have been wrong.
I have only replaced the belts since owning it once. I have all 4 belts here.
Hi guys, I'm not sure if this helps out or not but..
I took all the belts I have from my rideon (old & current) to my local Bursons Parts Store. Using their Dayco Belt Tool, here are their measurements, as outside belt lengths.
Current Drive Belt = 10A x 2110mm
Current Deck Belt = 10A x 2240mm
Old Deck & Drive Belts = are both the same at = 10A x 2240mm
Note:- 10A = 10mm in width x 9mm in depth
Hi Steve,
I was hoping your first post at the top of the page, the part numbers may of been
correct but that would be.
Drive Belt - 532140294 that you had listed and is (1/2" x 82") and your current measurement is
2210mm is approximately 83.07 inches.but the old belt you say is 2240 mm which is 88.19 inches
Deck Belt - 532144959 at top of page is 95 inch V belt and you have 2240 mm
for that which is 88.19 inches.
All the Husqvarna belts I look up are half inch wide .
I can't find any manuals or specs online for a 1989 Husqvarna ride on,
the closest I found is 1995 and those belts are not listed for fitting earlier models
so I wouldn't go on that manual for part numbers for the V belts.
The only part numbers I found online that had the same length belts for
the drive belt and cutter deck belt were the Husqvarna 954140005K 88 inches drive belt Husqvarna954140005F deck belt 88 inches deck belt
Some sellers online said if you cant find your model numbers for the
mower on their description of the V belts you should email them all
the mowers details and they will look up the correct part numbers.
Maybe someone else will have the correct manual for part numbers here.
Max
Hi Maxwestern, I think the Date I have posted is maybe the Briggs Engine date.. From memory (a long time ago), I did a search on the Engine Number and I'm now thinking that 1989 may be the Engine Build Date and not the Mower.
The Parts Manual you have linked to and the one I downloaded 10 years ago is the LTH130 - HALTH130C Model. Mine states it's the LTH130 HALTH130B. Both list the same Product Number stamped on my mower - 954 11 00-61 and as far as I can see and for the parts I have replaced, they are both the same..
Hi Steve, I haven't seen any pics of the pulleys with the belts sitting in position on them
OK Guys, thanks all so very much for your ongoing help with my belt issues.
I have spent the past few days going back through 10 of 1000's of emails and finally found what I was hoping to find.
It's the Emailed Invoice on the last set of belts I bought wayyyyy back in 2016 from Macarthur Mowers & Marine at Camden in Sydney.
Drive Belt = Husqvarna:- 532 140 294 - Stens:- 248-082 - Size:- 1/2" x 82.5"
Deck Belt = Husqvarna:- 532 144 200 - Stens:- 265-092 - Size:- 1/2" x 88.5"
These are the belts I have just taken off the Mower and looking to replace.
Kindest Regards
Steve
Hi NormK, I posted 2 photos yesterday at 10.30am.
One photo shows the belt in the Deck pulley and the other shows the belt in the drive pulley.
Maybe you have to refresh the browser window as you have been there before.
Steve
ajgreeny, MarkusB, briney91, Dinah, rancherman
18,074 Registered Users
Topics12,747
Posts106,768
Members18,075
