4 members (Bruce, MowingManiac, Dandare, TastyFishes), 5,798 guests, and 675 robots.
by Bruce - 30/10/26 08:38 PM
by Bruce - 30/10/26 08:35 PM
#121079 04/03/25 07:07 PM
G'day all,
I'm Xav, 16 and I love engines, Bikes, Cars and the like. Been looking at purchasing an old rotomo for ages now, and I finally bought one on Sunday. I got the mower along with a heap of spare parts, a spare engine, and an old fuel tin. Just here to share the build and seek advice or help. Attached is a photo of everything that i got. The mower i believe is a Special Engine and recoil on an earlier body. Just have to identify the carb.
Cheers Xav
Turning grass into lawn!
Hi Xav, welcome here,
What you have there is a good example, looks in pretty good condition with a good aircleaner, wheels and pull starter. Looks like it could go straight to work as is
NormK #121082 04/03/25 07:45 PM
Hi NormK,
Thanks for the warm welcome. I've been getting straight to work but struggling with spark. I plugged the spark plug into a different mower and it went no problems. There is current going through the spark wire (you can get a zap) but it doesnt want to spark. I've gapped it at 0.028". Any ideas? All i can think of is the magento needing more spin than i can provide while viewing the spark plug to create enough voltage to spark.
Hi Xav
It can be a can of worms and if you don't have parts to mix and max so you can fault find it can be hard. My first starting point is a bit of starter fluid in the throat of the carby. If you get an attempt to start then you can say you have enough spark for it to run and it also tells you it most likely hasn't been straight fueled. Then you can assume that it is a carby problem so you can concentrate on that
Hi xsancanin ,
It's a fairly clean looking Victa 18 Special https://www.vintagemowers.net/Victa_Specials.php
The carby is a 3F model.
There are a few manuals here for a carby rebuild and to sort out the magneto.
If Links aren't working in this part of the forum ,highlight the text and right click open link in new tab.(see pic below)
https://www.outdoorking-forum.com.au/forum/ubbthreads.php/topics/109944.html
I'd file the points adjust the gap set the timing and replace the condenser ,the condenser is available on eBay .
The carby may need to be dismantled and cleaned and check the float level.
Moderated by  bigted, Bruce
18,195 Registered Users
Posts106,840
Members18,196
