2 members (Bruce, noileg), 4,506 guests, and 1,330 robots.
Page 2 of 3 1 2 3
It is cutting the round hole in the plate for the motor to to sit through is the problem. Hole saws will do it but it is hard work
A 30mm hole cut with a decent hole saw like Sutton through 6mm plate tales about a minute and a half if you drill a clearance hole first
Norm.
Mark the hole with the hole saw then drill a 10 mm hole or bigger on the edge of the circle this will remove the swarf ,I also use an
oil can for cooling and Lubrication.
You can use this method to drill through 2 inch thick steel .I usually use an old Sher 2 speed drill set on slow speed with a 1/2 inch chuck.
Yes Max,
The hole to fit the bottom half of the crank through is about 80/90mm in diameter. I do all that sort of drilling in my drill press but plasma for that stuff is so much easier. Problem is all this stuff adds up and as you know there is no money in fixing mowers. I need a plasma, a bottle of migshield gas and a bottle of oxy and a bottle of acetylene all ads up and it is hard to justify when I am nearly 80 years old
Hi All
As I have an older 2 Stroke Green Base Rapier 2 Blade Lawn Mower. What I might do is use the 4 Blade System from the newer Lawn Mower on my older 2 Stroke Green Base Rapier 2 Blade System Lawn Mower.
This way I can keep cutting the lawn without worrying about not being able to start it after turning off for 10 minutes.
Thus, this will allow me, plenty of time to pull it all apart, clean everything and source a new Throttle Cable and G4 Carby as I am now thinking the issues stem from there. If i pull everything apart, I can do the Large O-ring replacement and also see if I can borrow a proper Compression Tester to check compression.
I will persevere, it might take me months, but I will try to remember and post what happens
Hi All,
A small update.
I purchased a cheap Compression Tester from Ebay. So I can test it's compression.
With the Decompressor in place , I get 25psi.
Without the Decompressor and the hole plugged, I get 35 psi.
Is these figures correct for a Powertorque Victa 2 stroke lawnmower.
Also I pulled off the Carby and noticed I have quite bit of dirt inside the Carby air intake. It looks looks very dirty from dirt being sucked in. It seems the clamp that goes around the hose and Carby does not Seal enough or it is getting sucked in from the top of the hose.
I am hoping for advice from someone that knows what should the psi of these lawn mowers should be. If it is too low I can pull it all apart and replace the O-rings and Piston Rings.
Harry
Hi Harry,
The lowest compression that I would use is 50 psi with the comp tester on the end of a flexible hose without the hose compression
probably is around 65 psi.
It's usually cheaper to buy a good mower at a tip shop for $10 to $20.or gumtree ,garage sale etc
Hi Max,
Thanks for the advice.
Good point about a Tip Shop or Gumtree.
Let's see what happens.
The moral of the story is I should of bought the cheap Compression Tester at the start it would of explained a lot.
Hi Max,
Can you please have a look at the below pictures and advise if I purchase the below kit from Ebay will it work or am I wasting my money.
Harry
G'day Harry,
That bore looks worn enough to at least need honing ,but it depends after the bore is honed and the piston is measured as well as measuring the bore wear then the maximum clearance should be no more than 11 thousandths of an inch to be suitable for new rings.
A new piston should not be used in an old bore.
OutdoorKing have a rebored engine for $80.https://www.outdoorking.com.au/clearance-items/victa-power-torque-rebore-err1352n
PowerTorque manual https://www.outdoorking-forum.com.a...del/Power%20Torque%20Engine%20Manual.pdf
As your 2 stroke mower engine was so low in compression I wouldn't spend time fixing it as a replacement mower is
cheap on FaceBook Marketplace ,Gumtree ,eBay
I've seen piston ring sets for around $15. online but depends how worn the engine is.
That 11 thou clearance sounds a lot from the manual as usually motors are about 2.5 to 5 thou maximum piston to
bore clearance
A full crank 160 cc Victa 2 stroke maximum clearance between piston and bore for new ring replacement is 8 thou.
There's always people giving away mowers.
G'day Harry,
Hi Max,
Thanks for the Manual. much appreciate it.
An Update,
The Old man got a 2 Stroke Lawn mower from his friend.
It is a Victa Pace Model PAS201G.
It has no Decompressor installed. There is no hole for a Decompressor at all.
The Lawnmower seems to have been taken to a repair shop that said it is not repairable. (Compression???)
The first thing I noticed was it has the white carby cover on 90 degrees from horizontal. Easy fix anyway.
It had its pull cord mechanism pulled off, so I could see the Piston rod. The whole area was pretty clean, so it doesn't seem to have sucked in any dirt.
I decided to put it together and see what its compression was.
Since it has no decompressor there was no need to plug the hole with a Spark Plug.
After pulling the Cord 5 times, the Gauge reaches 60 PSI.
It isn't 80-100 PSI but better than 35 PSI I get from the old motor.
My question is do I proceed overhauling the Carby and installing the Float Lever and testing.
I know Maxwestern mentioned no lower than 50 PSI.
Or do I wait to find another lawn mower with a better compression.
Harry
If you wait then nothing will happen...if you go ahead the better mower will turn up! It's a win win situation.
Danny
Hi Harry and Dandare,
Most Compression testers aren't accurate ,50 psi is the lowest I'd use with my comp tester as I know the real reading will be at least 65 psi
and have used mowers like this for 10 years and haven't had a problem.
here is a video showing how far out different comp testers can be.
I'd go and fix the carby and use the engine with the higher comp.
You can run a mower on 65 psi ,below is a LawnBoy motor spec that has minimum 65 psi cold.
If the Schrader valve isn't at the spark plug end on the compression tester the flexible hose just adds to the compression
chamber volume ,thus giving a lower reading.
Hi Dandare and maxwestern,
Sorry for the late reply, I was at the Parents.
Good advice Dandare, I just thought more knowledgeable people might advise otherwise.
Thanks Max for the attachment and additional info. That's the exact Compression Kit i got (Red One). I will view video after this post.
I plan to pull off the Carby tomorrow check it out and if required use the newer parts from the other carby on this carby with the float Lever.
And give it a try, if all goes well I will transplant the Motor onto the newer base.
Thanks for the reply max.
Harry,
If you are going to start this motor make sure it has a blade carrier on it because without it it will give you a severe kickback, hurting your fingers
Originally Posted by NormK
Harry,
Hi NormK,
Thanks for the advice. The aim is to fix it on the current base and then when I am sure it is working remove the motor and install it on the other base.
Just a reply about the Video on the different comp testers ,I can't believe how much of a difference he got with the 2
readings,I suspect the o ring was leaking on the cheaper red box tester as he said he only tightens them finger tight
so it could have come loose or compression leaked past the o ring as I've had the o rings leak compression before
on testers unless I tighten the plug hole fitting with a socket so it's tight.
When I tighten the tester tight in the threaded hole the O ring eventually fails and needs to be replaced but now
I have just installed a spark plug washer on my comp tester threaded connector.and that should last for ever.
The longer the flexible hose the more your reading will be down from the correct reading if the
Schrader valve isn't at the spark plug end on the compression tester with small engines.
I checked a Victa 2 stroke 160 cc motor ,the short comp tester has the Schrader valve at the end that goes into
the head of the motor and the longer tester has the Schrader valve up the other end near the gauge.
I get a reading that is 20 psi different with the two comp testers (longer tester is 60 psi ,short tester is 80 psi)
I usually like a small motor to be on at least 50 psi with the longer tester so that may be 70psi for a cold reading and
is the lowest I will use a mower ,I find the mowers can still last 10 years but can stall a little easier in long grass,they will
start straight away after stalling hot but find any lower comp reading and they can be a pain to start hot after stalling
in longer grass , most people prefer at least 85 psi as a lowest compression reading.
The short tester may be a little low reading also because you are still making the combustion chamber bigger
with this tester than if you had a spark plug installed.
Hi max,
My Chinese made Compression Tester does have a Schrader Valve at the bottom of the hose, but as usual it does seem to leak when you are blow in the hose. So you get what you pay for.
Sunday Update,
After getting 60 PSI cold , I cleaned the motor and installed the Float Lever, pulled apart the carby and checked it all and put it all together. After endeavoring to get the throttle cable to work properly. It seems to work now. You can go half way, it finds a bump and when you push a little bit more it clanks and goes to full throttle.
So
After priming a few times and pulling the cord a few times it started. It smoked around the exhaust and settled after a while. I run it for a little bit and turned it off.
After having it off for a few minutes, I decided to start it again. Unfortunately this time it did not start. I pulled out the Spark Plug and tried to check Compression. Well would you believe it compression when hot is 45 PSI. 5-10 minutes later it reads 55 PSI. 5 -10 minutes after that it got back to 60 PSI.
Unfortunately this motor seems to also have a Compression issue too.
I did adjust the Poppet Valve back to A, I found it about halfway between A and C. Would this affect the restart when hot. ( Poppet has 4 A C)
Any advice
I'll need to keep looking for a Hard Rubbish 2 Stroke Motor.
Hi Harry,
Yes I've had the same problem when the motors are below 70 psi cold with an accurate comp tester (sounds like your tester
is accurate with the Schrader Valve at the bottom of the hose,) They are hard to start hot when the compression is down..
If the tester is slowly loosing pressure after a test you may be able to replace the Schrader Valve to fix it.(it should screw in)
The carby poppet should be set to C but this setting won't effect starting it's more a long term setting so it's not too rich or
too lean.
The two choices would be, one look for another (engine / mower ) or two just put some new piston rings into this motor
that is on 60 psi cold.
If you replace the rings you will need to make a tool to get the conrod / piston out. (just cut an old socket up)
https://www.outdoorking-forum.com.au/forum/ubbthreads.php/topics/33821/1/victa-special-tools.html
Hi Max,
Thanks for all the info.
Just a set of standard Piston Rings, not oversized.
Harry
Yes Harry if the bore is standard size ,they usually are, just use standard sized rings.
Thanks Max,
It will be a while until , I re-post again.
Better if you can give the bore a hone to get it freshened up
Yes Norm it would be better, but I didn't mention one because if you are only repairing one engine and a hone is about $20.
plus new rings and a head gasket ,it could be a better option to buy a used mower .
Harry mentioned the motor looked clean with the starter off and if the bore looks good, I've fitted rings without a hone
and they bed in after a while.
I think you can get away without a hone if the wear is minimal; often, simply replacing the rings with proper break-in procedures is sufficient for most situations.
I never Hone a Briggs with alloy bore.
If the bore looks ok sometimes I don't like to hone the bore as the piston is already close to it's maximum bore clearance
so I don't want to give it any more clearance from a hone.
When I do use a hone I put 1200 wet and dry around the stones so the very minimum is removed.
Always pays to check the ring gaps in the bore before putting them on the piston as well, not that it is a problem usually but always pays to check
Hi All,
A question from Sunday's Update.
When I was cleaning everything and installing it back together I noticed the vacuum control button fitted on the motor housing, that has a hose connected to it and the Carby Cap has no hole on it. The other faulty motor definitely has a hole on it and thought it was strange.
Is this the reason why it seems to clank to Full throttle as there is no air pressure at the top of the Diaphragm. I tried starting it on cold position and it wouldn't start, i pushed the throttle forward just before it clanks to full throttle and tried again, It tried to start and once I push it over the clank to full throttle it started.
Throttle Cable is smooth, no kinks in it. I have tried it without the Red Spring and Carby Cap and it does not jam at all. It seems only when the Spring & Cap are on.
Harry
Hi Harry,
The carby diaphragm cap should have a vacuum line connector on it .
With the throttle cable sticking or jamming ,I usually just bend the cable to stop that ,see pic below in the red circle,
that is what the end of the cable that goes into the carby looks like after it's bent to stop it sticking.
Max..
And that is why I cut the3 lumps off the lifter, no cable jambing for me, nice and smooth
Hi Max,
Yes the Diaphragm cap has a vacuum line connector on it, it is at the end of the tube where it connects to the Motors frame that has no hole in it.
Thanks for the tip about the bend, I might give it a go and see how it goes.
Hopefully during the weekend.
Hi All,
Saturday Update 8/3/25.
I have moved the Poppet Valve to C.
I have not bent the throttle cable as mentioned by Max.
I still have the original vacuum control button without a hole that is fitted on the motor housing and is connected to the Diaphragm Carby Cap vacuum line connector still on.
I tried starting it on cold position and it wouldn't start, i pushed the throttle forward just before it clanks to full throttle and tried again, It tried to start and once I push it over the clank to full throttle and pulled the cord it started.
So it seems to like to start in the run position only.
Does having a Vacuum Control Button without a hole effect the way it starts.
Secondly
Also I ran the lawn mower for 1/2 hour and tested its RPM and Compression. RPM was 3660 RPM and Compression was about 60 PSI.
I tried to restart the Lawn Mower on Run and it started after the Second Pull.
This time I ran it for another 20 minutes and its RPM was about 3820 RPM and Compression was about 55 PSI.
Again I started the Lawn Mower on Run and it started after the Second Pull.
This time I ran it for another 30 Minutes and its RPM was about 3660 RPM and compression was about 53 PSI.
At the moment my lawns are very dry and its a dust bowl. (The lawn mower is covered with dust).
So having a Vacuum Control Button without a hole affect the way it starts, and does the above RPM and Compression readings , still warrant a Piston Ring Replacement. I am happy to do it , if it will help compression & starting. Also to replace the Vacuum Control Button with one with a hole.
Harry
Page 2 of 3 1 2 3
18,183 Registered Users
Topics12,763
Posts106,823
Members18,184
