1 members (bigted), 8,136 guests, and 2,016 robots.
Hi
I am restoring a 1964 Victa Corvette 160cc Mark 1 70 series 2 stroke engine number 96801690. I just noticed in an other tread picture that the head gasket is paper and not metal, mine is the same and I thought that someone in the past made a mistake hence all the oil that is blowing on the cooling fins.
Now I am confused should it be paper gasket or should I replace it with multi foil gasket sheet that I have to cut it out?
Also the the priming pump with the little spring that look like it is from a pen needs an o ring, mine is out of shape and sit between the spring and the washer at the base, I put it under the washer but it doesn't grip the pin, so I'm guessing fuel will leak. Any help would be much appreciated.
Thanks,
Rich
If you look at the thread VC160 restoration you will see Max has given you the information you wanted
Thank you Norm
Moderated by  bigted, Bruce, CyberJack
18,215 Registered Users
Posts106,871
Members18,216
