3 members (Gizmo, Dandare, Red Rum), 636 guests, and 1,600 robots.
Masport Shitemaster 720 blade
Page 4 of 5 1 2 3 4 5
Hi Max,
I think the tiny reamer is the best option, it is nice and sharp and I can control it easily in a small chuck and give it a couple of turns with a bit of pressure on it. It pulls out small shaving of brass. I don't think there is much between the different suppliers they all seem as bad as each other, they are all coming out of the same factory. I would like to do another half dozen just to see if this is the answer
Latest update is all 4 mowers fired up this morning, a couple fired up and stopped a couple of time but eventually fired up and ran fine. Can I say for sure this fixes the problem, I'm not sure but at this stage I feel comfortable with these 4 that they have been fixed. I have wasted massive hours dealing with this Chinese junk but hopefully this info may help somebody in the future
Checked a couple of them today to see what was happening, one started up fine but the second one just flooded out the primer bulb. I guess I can live with a 50% strike rate
I noticed in a tin of stuff that I inherited that I have red, white, grey and black plastic needles.
Danny
Hi Danny,
you can always try them nothing to loose, just a bit of time. The different colours are different lengths, you put the needle in the cap and put the float on and put it up to the light so you can check when the float is up the float doesn't hit on the body of the cap. When you look at it you will see what I mean. Then fit the cap to the carby body and see what happens, either stick up or flood out the primer bulb
I need a yellow to complete the set...or are there others?
I was given a Victa Tornado mower (blue one) earlier in the year from a bloke who still seems to find stuff by the roadside (Campelltown NSW area}. I used it back in May and it started first time and worked fine. I went to start it a week ago and nothing, then noticed fuel dripping out of the primer cover(not the bulb).
I pulled the cover and the black needle was reluctant to part company with it's seat. Anyway, cleaned it all up, dropped everything, cleaned it all up, put it back together again and after blowing out the filter and, just because I came across some, gave it a puff of Aerostart down the tube.
Went like a bought one. I suppose I can expect more trouble with that plastic needle? I have learnt that the black needles are probably hardest to find on the garage floor!
Danny
Hi Danny,
There is no science or black art with the needles, it is just a complete crapshoot, keep trying till you find something that works and then keep your fingers crossed that it continues to work
Latest update from the front.
Of the 4 motors I set up with the reamed seats, 2 are now working fine as I have been starting them once a day and they fire straight up. The third one is a PT on a 24 and it starts but takes several pulls. This 24 is one I filled the pulley with lead and I'm thinking the starting problem is most likely the lead is not quite enough spinning mass to allow the motor to kick over. It still has a minimal kickback on the odd occasion so I will work on adding some extra weight.The 4th motor, sometimes fuel pours out of the primer bulb so this one I believe is a needle problem. One interesting thing is that on these 4 test motors I have used needles that I have previously rejected as faulty so now I believe the needles were not the cause of all the problems, it was the seats in the new primer caps all along. I will go through all the reject needles I have and test them all but I believe they are only a minor part of the problem. The saga rolls on
Keep going. You may yet crack this. We appreciate the field reports NK.
Hi Norm
Out of interest, as it seems the seats have been the problem the whole time, perhaps a good test would be to set up a test rig that will hold a primer cap and have a sizable tank above creating decent head pressure.
Then ream the seat and put a completed cap in the apparatus with an old plastic needle. If the bore of the seat is smooth enough to decently seal on a plastic needle, it will seal great on a viton tip and in theory would have no burr to catch the rubber
Hi Tyler and MF,
Yes Tyler might be worth a try, see how that works. I now have another issue with the carby I am using which I thought was working fine. Runs 2 mowers fine, but the other 3 I am testing start up fine but will only continue to run if I give the primer bulb a pump everytime the motor starts to die and sometimes just holding my finger over the primer bulb hole is enough to keep it running although it doesn't have any throttle control. I'm thinking might be an airleak problem somewhere. It is obviously a fuel flow problem somewhere
Ok so does anybody have any idea why pumping the primer bulb allows me to keep these motors running. I'm wondering if it might be a slight leak through either the top or bottom seal which means it is just not quite able to draw in enough fuel to keep it running. Any other thoughts?
I've had motors that I had to keep pushing the primer to run because the fuel needle was sticking and the motor was not getting enough fuel.
Easiest way is to put a carby of a running motor and test it that way.
Hi Max,
This is a carby I have been using on several motors to test them and the float needle. Several motors run fine using it but I have 3 that will only run with the carby if I pump the bulb
Sounds like a air leak as you say Norm
I would check for a slightly stuck decomp valve or weeping head gasket before checking crank seals. Blocked muffler could also theoretically cause poor port scavenging so it needs a richer mixture in the fresh charge its getting each stroke
Are they going off flat out like a air leak
Hi Tyler,
No sign of revving up as you would expect for running out of fuel, just running calmly and then the revs drop and without pressing the primer they will stop. One pump and it will run fine for5 or 10 seconds and then i have to pump the primer again
Hi Norm and Tyler,
I usually do a compression check on every motor Norm.
If I suspect a restricted muffler , I'd just start the motor with the muffler removed.
May be worth looking in the exhaust port to see the condition as the engine may have been straight fuelled.
Check the spark isn't weak and timing is correct.
Hi Max,
Think I will just move on to other motors and see how the carby works on those. Strange thing with these motors is they start first pull and run smoothly as long as I give the primer a pump every 5 seconds or so. It is such a big job building the carbys for the 24's because I have to shorten the short Utility snorkels by 120mm to make them fit and then do all the carby mods. Very time consuming and I am stuck working on my fish pond and that is taking a lot of days up so mowers are taking a back seat. Pity because I will not be able to get 24's ready for this mowing season which is quickly approaching. Fish pond had to be sorted because it hadn't been cleaned for probably 8 years
Just for anybody wondering why it is going to take me a while to get this fish pond sorted here is a pic of it.
And then to add to my annoyance with these float needles and primer caps, a mower which I thought I had finally got working I thought I would give it a try as it had been sitting for several days. Prime it starts first pull, runs for a few seconds and stops. Did this several times and then I pumped the primer to keep it going, did this about 3 times and then it started running without have to pump it. There is no way I could ever get these things reliable enough to sell. these chinese parts are just garbage
The fish pond looks a lot bigger than I thought it would be,that will keep you busy for a while.
Could be crank seals are bad on the old 2 strokes as the symptoms of leaking 2 stroke crank seals are a lean idle, a flat spot at low revs or an engine that will not rev out. In some cases, the motor will not idle at all.
Probably just easier and cheaper to grab another motor otherwise you would do a leak down test with the ports blocked off and 5psi
in the spark plug hole for 5 minutes to make sure the pressure doesn't drop.
Some people say just leaving a 2 stroke motor unused for a few years will dry out the seals enough that they need replacing.
I've had 2 strokes do what you describe and had to keep pushing the primer to keep it running with the plastic float needle but
after fitting another needle the motor worked fine ,always felt like the needle wasn't letting enough fuel in when I had to keep it running
by pushing the primer but easy to see if it's a carby problem by spraying 2 stroke fuel into air intake when it's running.
If the motor won't rev out with out extra fuel or won't rev out at all then it looks like the seals are leaking, if it's not restricted on exhaust side
and no other faults.
Hi Max,
yes the pond is a big project, hope I am up to the task and too hard for me to get enough dirt up there to fill it in.
Not sure what to make of these motors, I guess one way to prove it one way or the other is to replace the seals and see what that does
I remember reading that the primer bulb just introduces air into chamber as the fuel is of course gravity fed? If this is right then what scenario would cause these problem ones to require more air?
Am I misunderstanding the whole thing?
Danny
G'day Norm and Danny,
The primer pressurizes the float chamber with air to force more fuel into the engine , not to force more air into the motor.
I've had a few Victa 18 mowers that only revved when I clamped the snorkel mostly closed creating a choked motor
making a richer fuel mix to compensate for air leaking into the motor from worn crank seals.
If it's difficult to get dirt to the pond you could always fill most of the hole with old wood ,like old pallets ,I've heard of people
filling holes with wood chips.
I've filled a hole before with half burnt wood and put a little dirt on top.
There's still a few ways to check the seals that won't take much work ,some people fill the crank case up with diesel and when
the seals are bad, diesel will leak out past the seal in a day or 2 on the lower seal.
Another way is to start the motor without the blade plate and spray starter fluid at the seal and see if the motor runs different
when spraying the seal and some people instead of using starter fluid use oxygen from an oxy acetylene torch.
I've had a few 2 strokes that needed new seals and when I slid a 1 thou feeler gauge between the crankshaft and the seal
the feeler gauge had no resistance.
If you still have Victa bases and are after any late model Victa catchers let me know before I throw them out Norm as I have about 20 still here that have been dismantled (in 2 halves) so they can be stacked inside each other (takes up less room) they just clip back together
then you put the 2 self tapers back in when you want to use a catcher.
Hi Max,
Unless I can get past this float needle problem then there is not much point in me getting the catchers, which is a pity, but as you know I am unable to be confidant in keeping these carbys working so I'm thinking I might have to dump all the 2 stroke stuff I have here. Pity but no point in me flooging a dead horse and these primer caps are just that.
Yes probably better to put the mowers into scrap these days ,I asked at mower shops here if they wanted undamaged catchers
for free and none of the shops here wanted them.They just want to sell new equipment.
As we know with the needles you just have to know what the cause is of the problems then fix it ,one thing that stops a needle sealing is
if the angles are wrong on the seat or needle ,too wide a seat can cause a sticking needle, a loose needle in it's hole can
cause the needle to not sit straight on the seat also if the tang on the float is on an angle it pushes the needle sideways and
could also cause a leak.
I've also heard some of the Viton tipped needles from China can be rejects.
Yesterday I spent 30 minutes modifying a Victa cap ,I took a rubber seat and alloy needle out of a Tecumseh carby,
then just drilled the brass seat out on the Victa cap then pushed in the rubber seat (had to modify a bike spoke to get a seat
out of the Tecumseh carby)then just shortened the alloy needle and drilled a small hole at the float end of the needle, then
tied the needle with fuse wire to the float.
Probably only take you 10 minutes to modify one when you have all the tools and parts.
After putting the modified Victa cap onto a mower it ran fine and didn't flood.
Another way I've thought to fix these Victa caps is to use a small ball bearing on the brass seat as a round ball always
lines up correctly with the seat, even if the needle is on a slight angle.
Re the ball bearing...I would want a good stock of those cause I would loose it every time I took that cap off. smile
Danny
Hi Max,
several years ago I was pulling the seat out, drill down with a 3/16th drill and fitting a Briggs viton seat and then turning the needle down so it would fit in the 3/16th hole and shorten the needle to the correct length for the float to operate. This was before the carbymaster came up with the viton tipped needles
Hi Danny and Norm,
You could always glue the ball bearing to the push rod .
The good thing about the Tecumseh needle is that it fits the 3/16 hole Norm , so saves work because it doesn't need turning down but
you would probably need to buy 12 seats and needles to be cheaper and pay no postage.
About $4.50 for one Tecumseh needle with seat.
I also like the alloy needle because it's easily drilled so it can be tied to the float.
It's probably less work than trying to polish the seat to get the Viton needle to work.
I'm tired Max, these needles have been wearing me down over the last several years and I'm starting to loose interest in wasting time on them. And then today I get a bloke turn up with a pressure washer he wanted fixed. It was apparently leaking out the pressure relief valve so I pulled that out and cleaned it and put it back together and it seemed to be working ok. He said he had another one at home but it was hard to start and could he bring it over later. He finally rocks up at 7.00pm and he pulled 2 dismantled pressure washers out of his van and a couple of boxes of bits. I couldn't be bothered to tell him to piss off, I just said dump it there and I will look at them tomorrow. I think he will be told to take them to the scrap
Yes it's not worth it for me to sell mowers Norm as most times I would make one mower from 3 and these days it would cost
me more in fuel to pickup 3 mowers than what I'd sell one for.
I picked up a MTD that ran well ,not smoking but just threw it in the scrap pile.
It's always a problem when you sell cheap mowers and the buyers expect you to repair equipment or one of their mowers for virtually nothing
but I would just say to them I can sell you a repaired mower for the same price I will charge to fix your mower and then they didn't want
their old mower repaired and just bought a repaired mower.
I've seen second hand working petrol pressure washers for $50. and new are around $400. ,so not worth spending much
time repairing them.
I have at least 5 here that I've never looked at because I have working electric pressure washers ,the petrol washers are
always on the side of the road here ,some look fairly new and probably just need a carby clean.
One washer I picked up many years ago has a Vanguard 16HP V-Twin Petrol Engine , from memory I think it just needs rings.
I was sick of people that I would do small repairs for free but they would say they would roll up at a certain time then change the time 2 more times and would do the same when picking up the mower ,so I just had to say I don't do repairs.
You can get a lot of time wasters ,I once sold a good working 2 Hp air compressor for $20. and the guy spent nearly 1 hour
testing the compressor before buying it.
18,062 Registered Users
Topics12,746
Posts106,765
Members18,063
