0 members (), 3,045 guests, and 2,329 robots.
#117689 10/03/23 02:52 PM
wce
Offline
Hi all
Picked up a Tiger el cheapo mower from verge pick up, I dont usually touch them but this one looked almost new. Put some fresh fuel in and it started first pull and runs well but the throttle lever doesn't seem to alter the engine revs. Are these a fixed engine speed affair or adjustable ?
wce
wce #117690 10/03/23 02:59 PM
Fixed speed wce, only thing the throttle does is the choke. Much the same as most sanlis post 2017ish
wce #117694 10/03/23 07:05 PM
wce
Offline
Thanks Tyler
Is there an adjustment screw to give it a few more revs ?
wce #117695 10/03/23 11:52 PM
there is an adjustment screw near where the throttle cable mounts to the governor. it is a rear facing spring loaded bolt. Unscrew to raise rpm
wce #117696 10/03/23 11:58 PM
here is the screw. Ignore that some idiot connected the throttle cable straight to the governor arm
wce #117698 11/03/23 10:25 AM
wce
Offline
Many thanks Tyler
wce
wce #117699 11/03/23 11:55 AM
Hi Tyler,
That is a bit harsh, I have connected a few throttle cables to the governor arm because the governor has failed internally. I have only done this on bigger motors that run well but have no throttle /governor control. What has been done in your pic is way off the mark and cannot control the revs, be either flat out or stop. What you have to do is take the arm that goes to the butterfly and fit it as low down on the governor arm as you can. This slows down the opening of the butterfly on the carby. You then fit the cable to the hole where the governor arm used to be. You then have to clamp the cable outer somehow and that can take some time coming up with a fix for that.
wce #117702 12/03/23 12:16 AM
Probably should have elaborated on that point Norm
I should have said "some idiot connected it to the governor with no idea what he is doing".
As you say, it would be either flat out or idle. Even if he drilled the hole higher up the arm (and clamped the outer somehow) at least it will have more throttle control
18,145 Registered Users
Members18,145
