0 members (), 5,849 guests, and 1,254 robots.
Hello all,
Hoping to get some more information on the below utility.
I cant seem to find any photos with that particular engine.
the model code on it is AY 071-A 8
Thanks a lot!
Hi Bryan,
It a pretty standard 4 stroke utility with a 148cc Briggs and Stratton 200 series engine. I'd guess it's about a 1986-1987 model. It appears to be all original except for the Rover throttle assembly.
Cheers, Ted
Never seen a VIcta ute with a Briggs vertical pull.
Used to have a Rover from the 70s (disc base no side shute) with a yellow points version of that motor and a neighbour had a Scott Bonnar utility with a white one.
Your mower is missing the extra bit that goes on the discharge with a metal flap. Note the bolt holes.
Should still work fine though. Nice mower. I like the motor's orientation.
hey lads, thanks for the replies.
So that engine is the original engine?
I am completely new to the victa's so wanting to get into them and restore this one to as original as possible.
@bigted when you say the throttle isnt original, what does the original one look like?
Are parts easily acceessible to buy? Especially that side chute, thats probably the main thing I want to purchase for this
The little white sticker you got the model number off suggests that the motor is original. I dont have a pic of the original throttle assembly but they are definitely NLA by now. The metal side chute is probably also not available anymore as Victa have been using a plastic one for quite a few years now.
You’d have to get very lucky with someone having old stock to turn up a side chute. Occasionally they come up with online sellers but they’re often very expensive.
They’re not difficult to fabricate if you’re prepared to put in the time and elbow grease. I made a workable substitute for one of mine (an earlier model) by copying an original. I traced the original onto card to make a template and then transferred the template outline to sheet metal before bending, folding and welding to get the right shape. It’s not identical but with a coat of paint it would take an officionado to notice.
I got one off an older FC base that had been thrown in a mower shop skip bin. It was the only good bit on it. It replaced one with a crack and missing flap on my PT one. It came up like a new part after taking to it with a wire cup on an angle grinder and a coat of paint.
ch83989g is the metal flap original part number
CH85638G should fit but NLA - see if your local shop still has one
CH86936AV is the current part - again deck hasnt changed so should fit. but its a OHS safe shield so will leave a windrow as opposed to spreading it evenly.
As ironbark said, it wouldnt be hard to make with a bit of patience and a few tools
1 member likes this: bryan490
Thanks all,
@mowerfreak is there any manuals or old brochures that point out the different models you are referring to? (FC, PT)
I am picking up another one for parts tomorrow which has a side chute, so hopefully its in good enough condition.
@bigted I am assuming the throttle assembly that are on the 2 strokes, with the tubing, aren't the original ones for this briggs engine?
Originally Posted by bryan490
Thanks all,
Here's some links to four from 1972, 1980, 1982 and 1983/84 when the Powertorque (PT) mono block half crank motor was introduced and used with subtle changes up until Victa quit making 2 strokes in 2017.
All the utilities with 2 stroke motors shown, however, are the full crank (FC) engine, but the PT motor was fitted to the same utility base soon afterwards only with a modified engine mounting hole pattern to suit.
https://www.outdoorking-forum.com.au/forum/u...1/brochure-professional-range-c1972.html
https://www.outdoorking-forum.com.au/forum/ubbthreads.php/topics/92508/catalogue-victa-1980-range.html
https://www.outdoorking-forum.com.au/forum/ubbthreads.php/topics/92578/catalogue-victa-1982-range.html
https://www.outdoorking-forum.com.au/forum/ubbthreads.php/topics/70751/brochure-victa-1983-84-range.html
18,159 Registered Users
Topics12,760
Posts106,815
Members18,160
