1 members (Ryan S), 6,691 guests, and 1,981 robots.
by nath - 16/10/26 10:48 AM
#116496 26/10/22 07:46 PM
I got in first on a marketplace thanks to a lady friend.....
Never seen the triangular cover. looks Chinese... should be good.
speedy #116497 27/10/22 09:09 AM
Hi speedy,
I have had a few of these triangle shaped rocker cover motors end up here but I have never even bothered to pull the cover off to see what goes on inside. Not bad little mower for somebody living in a unit with a postage size yard to mow
speedy #116499 27/10/22 01:49 PM
Hi Norm and speedy,
It looks to be the same motor and chassis as the yellow YardKing. Yeah funny little valve cover but can confirm it has the usual under it, just oriented a bit unusual.
speedy #116500 27/10/22 06:55 PM
Got it going, mowed full lawn. need to look at govener as revs were a bit down. Didn't fix starter yet.Used my Bosch power starter..... and arm saver.
Sharpened bar blade. , didn't close cut... but OK.
I'll try to put disk on... get revs up..... and get rid of it.
cheers speedy
speedy #116501 27/10/22 08:34 PM
As MF says, same as yardking, motor made by sumec - directly controlled by the CCP they are as cheap and nasty as you can get.
They make the victa chondas as well. They have axed the triangluar head design and now back to square head
1 member likes this: speedy
speedy #116508 28/10/22 11:02 AM
The one I fitted a round Victa blade carrier with 4 blades on a Sprinter body it didn't seem a bad little mower. Only issue I had with the Yardking motor was that because it was self propelled it had a short shaft about 40mm from memory, which meant I had a bit of messing around to get the blade carrier low enough so the blades were at the right height
Katcando, Stackers08, Alroh tccb, ToniPaul, Abp5961
18,170 Registered Users
Posts106,819
Members18,171
