0 members (), 775 guests, and 796 robots.
Page 1 of 3 1 2 3
Hi Guys,
In the past previous thread, I mentioned about the needle lever. Now I would like to share a video of how this new prototype is installed and what's the benefits of having this lever and the Pros and Cons.
Pros:
1. Surely pulls the metal needle from sticking into the brass seat regardless of condition when float drops of when fuel level drops.
2. Ultimate solution to keep the viton tip needle as it is and not to compromised the hardness and sealing ability.
3. Will secure the needle in place without holding the float of worying in loosing or dropping the needle on the grass while servicing the carby.
Cons:
1. Not suitable for older plastic needle.
2. A bit tricky to install.
The good news is I able to convince the manufacturer to properly prototype the design and manufacture the part. Making the progressive die tooling is very expensive and the deal was I don't hold a patent the the manufacture is free to sell the product to other customers worldwide. I don't have much benefit but only the pride to be part of this Victa improvement and able to sell my design.
I would like to hear your comments and suggestions. You can see the video below.
CM
Hi CM,
You won me if Victa had done these couple of little things to the carby most of the problems would not have arisen. Had another mower back just yesterday with a stuck needle. Well done in pushing on with this idea I congratulate you. Hope it doesn't put you too far out of pocket, not sure how many of the 2 strokes are going to be around in the next few years and once fixed with this spring they will probably be kept forever so it is hard to judge how many to order. Probably have to order 5/10,000? This is the problem to get them at a competive price or a price you can sell them at.
Like the idea Carbymaster, will definitely be an improvement.
Had a stuck needle on my Vortex Mustang on sunday - my usual G4/Lm starting procedure of tapping on the top of the carby a few times can't be done due to the cowl design
Hopefully they agree to produce it
Also Hello Norm, welcome back!
Regards
Hi Guys,
Thanks Tyler and NormK for your insight. Just an update of the progress of this design and production. Below is our conversation with the manufacturer.
14 Oct 2021 8:54pm (Message Received) - For Victa needle valve, it is not available for so far. We found it is difficult to put the needle into the hole of cap when the needle is pre-assembleed on the lever fork. We are making the new design for it.
24 Oct 2021 11:44pm (Message Sent) - Thanks for making the prototype. It is a bit tricky to put the needle lever into the seat when pre-assembled. Please see attached short video clip to demonstrate how easy to install the lever.
26 Oct 2021 5:05am (Message Received) - Thanks for your video, we will check it again. We guess the reason you did it easier to install the lever is probably due to the thickness of the material you used. Please see attached photo of our CAD design.
26 Oct 2021 8:20am (Message Sent) - That was exactly my first concept but I disregard that design due to lateral movement of the lever which pushes the needle agains the wall. And advice them to redesign as shown on my short video clip.
26 Oct 2021 4:17pm (Message Received) - Thanks for your advice. We will go back to your design for the Victa needle lever, as we realized the float could not be a freely falling body with our design.
27 Oct 2021 8:38pm (Message Sent) - Thanks for the approval of my design.
16 Sep 2021 5:01pm (Message Received) - For the Victa lever, we are making the new tooling. We hope it can be completed at the end of this year.
Thanks everyone for following this thread and supporting this idea. Hope this improvement we to put this LM/G4 leaking issue to an end. We all love VICTA 2-Stroke.
Please leave a comment and I would like to hear everyone's thought.
I'm still looking for a float needle I can rely on, the viton tipped ones are still problematic
Hi NormK,
I understand your concern regarding needle sticking. Changing the hardness of the viton will also compromise the sealing property of needle valve. There's always a trade off. We have address the leaking issue and now we come up a good solution to address sticking issue. These two combination is the best solution. If the viton still have the leaking issue means it's not the viton. It is the seat that has wear on its surface. I have seen this wear using inspection microscope and I can post the image on ODK. Good thing is we have an update from the manufacturer of the Victa needle lever.
17 Feb 2022 4:58pm (Message Received) - About the Victa needle lever, we finished the wire-cutting of tooling, but need assembly, adjusting and correction. i will let you know once we have the sample.
Surely, you will appreciate this little fellow once we have it. I can send you FREE sample to try.
CM
Hi Everyone,
As an update, I just would like to share this video.
CM
Hi CM,
I like your work, but what I would really like is a float needle that works as well as any float needle in any other machine. The Victa design must take the cake for the worst ever float needle setup ever designed. The Viton tips are much better but still by far the worst ever float needle setup.
Finally from concept to final product has arrived. I have received few final sample float levers from the manufacturer. This need testing and I would like to nominate the following who followed this thread and my previous thread back in 2019 throughout the development of the float lever to try.
You will get 3 FREE samples each to try.
Please PM me:
Mowerfreak
Speedy
Tyler
NormK
Maxwestern
Converse
Jefffrombrisbane.
CM
Here's the new float levers
CM
Thanks Carbymaster
Have a problematic one I will give it a go on
Was about to order a tuning screwdriver from the ebay store anyway, so that way you can throw them in the same envelope and save some postage
Will PM you
Regards
Hi Joel,
I have received the float needle springs thank you very much and all the work you have done on these to get the carbys to work properly I am picking up another 30 motors in the next few days so that should give me plenty to try out Have you worked out a price yet. I haven't decided if I will fit them on every needle or just the ones I have problems with
Once again thanks for your efforts.
Cheers Norm
Hi CM,
I also have just received an envelope from you , thanks for the needle and 3 levers in the sponge ,I can try that soon as I have a lawn that needs cutting now .
Thanks Norm, Max and advance thanks to Tyler, Speedy and Mowerfreak, you guys will also receive your sample levers soon. Only Converse and Jeff didn't PM me. It's my pleasure and honour to be part of this Victa carburetor solution. I hope I won't be forgoten for the Victa 2-Stroke inthusiast for this small contributions. As we knew there slight difference on the genuine early G4 and late model LM primer cap which is almost unnoticeable but it does affect the fitting of this new lever. The early model is our reference of our primer cap which has 2.55mm float post or pivot diameter where the late model has 2.68mm diameter which a bit tight for the new lever to fit. Just a heads up if you wonder the lever is bit tight when fitted. You may sanding the post to 2.55mm-2.6mm instead of expanding the diameter of the new lever. If the lever fits in the post freely buy it doesn't drop the float freely, you may adjust the heel to release compression between the heel and fork against the float. I attached a photo of the lever with my own identification of ifunctional parts. If you have a better descriptive name please let me know as I want you to be involved of naming its functional part.
At the moment I only have limited sample production parts for trials. I have contacted the manufacturer to adjust the hinge diameter to fit on the later model primer caps since some still available as original parts on some PT. For the price, I have to make sure it's proportional to the COD and I don't expect this to be expensive than the needle. Profit for this lever is not my priority or not important for me instead it's my honour to see everyone benefits from this innovation. Hopefully we will get the final production for everyone to use.
Just today we send a complete G4 kit to Greece who purchased the parts through our website and I include 1 free new lever pre-assembled with needle, float and primer cap in a secured sealed plastic and float padding not to push the needle in, during the shipment together with other parts.
CM
Got mine the other day. Nicely packed mate! I'll have a play after I receive the primer cap package I opted to buy as well.
Hi Vm and all,
I have the float needle clip installed on a Victa ute with an early G4 carby ,the float post was 2.5 mm and as it was getting
dark soon after fitting the clip , I ended up watching the Video after getting the mower going and did some things differently.
The clip was tight so I pushed the hinge part of the clip over a 2.8 mm drill bit then bent the rear float tab ( or heel ) so it
was a little looser on the back of the float
The assembly that I did was put the needle in then the clip then slightly open the needle and clip and fit the float.
The float clip ,needle and float worked well ,I turned the engine off from the fuel tap a few times and as the engine cut
out from no fuel and as the motor was still spinning but not firing I would turn the tap on and engine would start running again ,also stopped the engine with the carby dry then turned the tap on and started the engine and all was well.
(engine did not scream out when running out of fuel so crank seals are good and no vacuum leaks)
I like the modified mulch plate on this Utility as now the mower can't stall in long wet grass. (the mulch plate now pushes air
out instead of downward)
This Utility is my test mower and I use it to cut wet grass, if I have to cut wet grass so has a few rust holes in the base also
is the mower that I have fitted an electronic coil from a side pull 2 stroke , this one would start just using a little finger on
the starter cord , doesn't take much effort or speed on the rope to start.
Have only cut grass for 10 minutes so far but have some long grass that will take an hour to cut so will give the float needle
clip another test later on.
I tried fitting one the other day on a Tornado that I had put new rings in but I had too much trouble with the clip and ended up giving up on that carby and ended up modifying another carby and got it running fine and then for some reason the carby started flooding with fuel coming out the primer cap. Hit the primer cap and it stopped flooding. This of course floods the motor and then I had to clear the crank of fuel again. It is up and running again but without the clip and the clip would not have stopped the flooding anyway so I am still fighting float needles as I have done for years
I am very tired of Victa float needles and the problems they cause
Hey NormK,
have you tried it with the specially made primer caps coming out that are fabricated specifically to work with the clip and viton needle?
It's good that you have shared your experience thus far with.existing primer caps and floats.
Maxwestern, could you explain what you have done to modify the mulching disc to shoot the grass more sideways. I have some four blade discs without flutes.
Did you just block them off or actually change how they direct flow?
Hi MF,
Brand new primer cap straight out of the bag and seat polished with Autosol as I do with every cap
Originally Posted by NormK
Hi MF,
Wow, and there's still a failure rate? Where do you source the caps from?
I bought 100 from CM
Sounds very frustrating Norm when you have fitted a new needle and primer cap and the carby still floods.
The mulch plate that was modified is just the flutes on the plate bent to a different angle than standard Mf , the standard
flutes point down so you just bend then up with a big shifter. The base in one spot needs a little hammering so the
blades don't rub after fitting the plate.
Mowed today for about an hour and 10 minutes ( 1 and 1/8 of a tank of fuel) and the needle and clip worked well,
carby didn't flood and the needle didn't get stuck.
One thing not mentioned yesterday was when mixing up 5 litres of 2 stroke , it was getting late and I only had two
and a half litres of unleaded left so also put in two and a half litres of 20 year old super fuel to make up the 5 litre mix,
the mower ran fine no problems ,I even put the same mix in a Stihl FS 36 line trimmer that I hadn't started for at least 10
years and besides the primer bubble that I had to replace as the old one was solid the line trimmer started and ran well.
Found another use for a Victa 2 stroke Today they work well to mow down an Agapantha you no longer want.
Hi Max,
I could not imagine the number of new needles and primer caps I have fitted that pissed out through the primer cap. I am just about done fixing these because of the needle problems. Eventually I get them working but the hours wasted with this problem makes it not worth the effort. I was going to pick up another 30 motors but I don't think I will bother now, just not worth the agro they cause
I just ordered another 30 air filters so I guess I have to fix another 30 of them. That means I have to find 120 wheels so I will be scratching through the barrels of wheels here
Well done Max! Nice outcome. I think you have the original primer cap and float if you didn't get those from us as they are also suitable for the metal needle and lever. Try to leave the fuel tap open for a week then start the mower after a week to test the needle and seat.
CM
Send me the troubled set of primer cap, needle and float that pissed out fuel. I will do the investigation and I will check seat with a microscope. One of the issue I have incountered same problem with the new primer cap and needle is when I test with a particular aftermarket float with a know issue. Once done with my investigations, I will send you a new set with my finding. Hoping your primer cap seat and needle tip were not deformed or damaged when polished with Autosol due needle sticking. Since we have the new lever, polishing the seat and needle is not required. PM me thanks.
CM
Hi CM,
I will PM you but with this float needle I gave the cap a hit with a screwdriver handle and that stopped the fuel coming out but once they have flooded like that the damage is done and then I have to remove the plug and pull it over several times to clear the excess fuel. Not a problem to me just an annoyance but if somebody has taken the mower home and then it plays up (over the time I have had many do that) I then have to go to their place to get it running again, they have then lost confidence in the reliability of the mower. One place I ended up going to 3 times to replace the primer cap and needle, luckily it was not too far away
Looks like you'll have to mow a lawn before you sell one. Offer to do a homeowner's lawn for free in the neighbourhood as the test track.
MF, I test mow lots of nature strips around my area, did a couple testing a Sprinter I had modified for the bloke who wanted a lightweight mower to put in his ute. I used 2 Sprinter bar blades to give it a bit more spinning weight, not that it makes much difference they are so light, from memory they only weigh 380 grams
Hi Norm ,
With the Sprinter you can also fit a cast iron Flywheel Norm ,I have a couple 3.5 Briggs cast iron flywheels here , cast iron flywheels are
usually on chondas when they are fitted with a light bar blade. I've sold a few Sprinter mowers to mower contractors.
The only thing that you may not have tried Norm is a new float , I've heard some floats bottom out before closing the needle completely
and sometimes I check the widths of the floats as that can vary ,you can put $12. worth of $2. coins (6 coins) in the carby then put the
primer cap on without the float and o ring and if that fits just make sure the float is smaller than the width of the coins, all the ones
I've checked were fine though.
I was looking at a couple of floats and one looked a little larger on the 2 pivot points , not sure if that would make a difference
without trying it on one with a leaking needle but I think by now you would have tried all the different combinations Norm.
Hi CM,
I haven't had any problems with the needle and clip so looks like you have solved the Victa carby problems CM, Success !
One strange thing is I haven't had the problems Norm has had with leaking needles ,but it could be because the majority if not
all of my primer caps are the CRO3501A OEM caps and I have heard they are matched to the black plastic needle so
most of the problems I've had were sticking needles when starting but most times they just needed more priming of
the primer and the needle would drop , the difference with CM's metal needle and clip is that the needle never sticks
so priming cold is only 3 times and always works.
Turned the fuel tap on yesterday night and the tap was on all day today and no fuel was leaking ,I will let you guys know how it is after
a week
Hi Max,
You might have given me an idea. I have had a number of Sprinters that kick back violently and maybe a heavier flywheel might fix it. Only thing that makes me doubt it might fix them is the fact that on all these motors to see if I could fix them I fitted a blade carrier off the 18 inch Victas to see if that could solve the problem but it didn't. I also tried drill starting one with a big old 2 speed Sher drill ( you know the one that breaks wrists if you get wrong) and it stripped the low speed gears in it. I was hanging on really hard. I throw those motor out now
Page 1 of 3 1 2 3
StewFuchs, Gib, auProspector, R Faurie, Steve Mack
18,093 Registered Users
Topics12,750
Posts106,781
Members18,094
