1 members (Gizmo), 3,200 guests, and 2,997 robots.
#115960 31/07/22 06:05 PM
I swapped this nice mower for an old Villiers engine..... And a carb for my Pope mower...
Looks rough, but I will get motor going and put it on big wheel Victa.....
It's a 60's mower. two stroke.
Rattle gunned off top and bottom nuts today , and head. Rings Ok, bore Ok. bearings OK.
Looking for forward to fun and challenge.........
bit crazy? speedy
Does it have spark speedy? that might be a problem
haven't got that far yet.
Senior Contributor
Early Pope mowers are getting so hard to come by. I'm sure you will get this one going speedy, but it will take time and a lot of work. I will post some photos soon of my Pope rebuild using parts from the early 60s to the mid-70s, and with a few repurposed parts from Victa, Briggs and Stratton and Tecumseh, other parts entirely re-engineered. Yep, I have finally completed this project. It took me 6 months!
Got the motor off base today, turns over, I sprayed some WD40 to get into bearings and past rings.... turned over a few times, didn't see spark, but I need to take flywheel off. It's an USA made Phelon FG 5152 magneto...Villiers used these as well.
Here's where I'm up to...................
heat. WD40. light levers....... heat wd40... there is no holes to put a puller in....... so I will let wd40 soat in under a bit of pressure... i don't to bugger it up.
It's usually easier to drill the 3 holes and tap them to 1/4 unc Speedy. 33. 3 mm from centre hole to centre hole
I also have one of these Pope motors but never had a chance to look at it.
I'll most likely convert my Pope engine to Honda electronic coil if it fits.
Thanks Max, I'll do that.... too much risk of breaking something and it's all a good exercise......
speedy, see if you can work out where the coil is and try not to drill into it because the coil might be ok to use with a module and usually if you hit the coil it breaks the drill bit
yes..... gently..
softly softly catchee monkey
morning Max,
why wouldn't I drill the holes in those raised pieces. It looks like that's why they are there.
Hi speedy,
you want the holes fairly close to the shaft to get maximum pressure on the taper. The further out you go the greater the risk splitting the wheel
Hi Speedy and Norm,
Some of the flywheels have a centre steel insert with the taper so you wouldn't want to drill into that and weaken the taper support or
weaken the alloy taper on the alloy flywheel ,the measurement is where the factory drills the later alloy flywheel and as Norm said
going out further could break the flywheel ,the alloy centre flywheel comes off really easily with the puller with the 3 holes.
The other way to remove them is to put the nut flush with the end of the crank then hold two levers that are levering on the
flywheel and at the same time hit the flywheel nut with a hammer.The motor must be off the ground to do this and is not easily done
by one person but I've done it this way a few times.
The drilling method saves time for the next time the flywheel is removed.
Not much alloy thickness in these types of flywheels when using a puller from the outer rim.
I'll drill in correct position. Yes Max I usually use the two levers and hammer. But don't want to smash it....
I'm getting attached to it now.......
To use the inner holes as designed I’ve found it’s best to start with a thru tap (in 1/4”) and then move to a bottoming tap. The thru tap should only be turned through four turns or it will punch through and create an opening for gunk to get into the electrics. I apply a bit of rocol rtd during tapping which allow me to easily pick up the swarf with a rag.
I have a harmonic balancer puller that I use to remove the flywheels; the one I use is an older unit and is smaller than some of those commonly sold today. The bigger modern models don’t let the bolts get close enough together or let you easily use the 1/4” bolts.
Another thing is to apply penetrant to the thread a couple of days before, this helps a lot. The sleeve on the flywheel can corrode and bond with the crankshaft and the penetrant helps.
If I feel any resistance I back off straight away and use heat differential to help me out. I then choose to do the job early in the day as it gets pretty chilly in my workshop overnight and the whole mower is cold. Having put the puller in my deep freeze overnight I use my heat gun to warm the flywheel. The heat expands the flywheel relative to the crankshaft and the puller works more efficiently.
I haven’t broken a flywheel in a while, I’m much more cautious since early motors and spare parts got scarce.
Morning Ironbark, I have a Ford harmonic balancer puller as well. I have used it with 1/4 bolts on other flywheels.
I've heated and let WD40 run down crack..... a few times...... I'm not in a hurry.
There's not much data around about this old Phelon magneto.... but I bet it's the condenser.........
Hi speedy,
and if it is the condenser just replace it with an ignition module
Senior Contributor
I thought I might have trouble getting my old Pope flywheel off. Believe it or not it simply lifted off in my hands. It is an earlier model than speedy's however.
won't come off. I'll leave it under pressure for a while.
Just looks like the puller having a coarse thread will give you less mechanical advantage Speedy.
The one I just used had a much finer thread and with the 12 inch shifter the flywheel popped off , I usually drill and tap
the holes all the way through but this one was not right through ,didn't even use WD40 ,the steel centered morse tapers
I will discard and replace the flywheel with the alloy centered one .
The GCV 160 coil should fit well on these engines.
Tried a difernet puller today..... no luck, but left it under pressure...
I'd go back to the car balancer remover tool Speedy and just hold the remover tool with vice grips and then tighten
the bolt as much as you can or just use a rattle gun on the car balancer remover puller bolt.
I haven't broken one of these alloy taperd flywheels yet this way, but when pulling the flywheel from the outer edges
they can break.
The one I removed took a fair amount of effort on the 12 inch shifter when tightening the puller bolt ,they always
take a fair amount of force to remove the flywheel from a taper.
yes I was going to go back to old ford puller.....
speedy, and when you have the puller tight, give the tightening bolt a hit with a hammer, that usually breaks them free
Senior Contributor
Must be like some of those old Southern Cross flywheels. They can stick there like they are welded. It will come free eventually and when it does it will let you know, although some come off more with a whimper than a bang.
Hi Speedy,
Try heating the flywheel with a heat gun or hair drier, that may help. cheers
thanks FG, been doing that.... today I held flywheel in fingers as mate hit nut on sharf with a few blows....... it's gotta go soon. There's a cam sleeve inside and a square pin that lockes all together, and some rust that has welded it........ soaking with WD49 heat . knocks
1 member likes this: FAST GRASS
I guess it probably doesn’t get that cold in Bundaberg but if you try it first thing in the morning when it’s coolest, freeze the extractor bolt in your deep freeze beforehand and use the heat gun on the flywheel that’d improve your chances of freeing it up.
They do get rusted on occasionally. I used to muck about with old cars a fair bit and found there was a crc penetrant product that worked a lot better than WD40. I can’t remember the specific label but I’d give rusty bolts and such a squirt every day for a few days and then found I had many fewer threads to rework and stud extractor kits were less frequently required.
The risky approach is to use an impact gun as that delivers shocks as it winds, risky because I’ve seen them pull the centre out.
The flywheel with the steel centre, tapered insert can easily get stuck tight to the crankshaft but even when the alloy flywheel centre
is corroded I've still never had one break .
I usually replace all the steel tapered centre flywheels with the alloy ones as they are much easier to remove and this is
what Villiers also did on their engines so the problem must have been well known.
18,068 Registered Users
Topics12,747
Posts106,768
Members18,069
