3 members (Ashgren, MowingManiac, Widget), 764 guests, and 2,485 robots.
Sharing My New Lawn Mower
by ccxue - 21/09/26 07:18 PM
by FiM - 12/09/26 02:12 PM
by mower1 - 05/09/26 05:51 PM
by NormK - 12/09/26 07:48 PM
by NormK - 09/09/26 05:07 PM
#115693 19/06/22 10:59 AM
I have a number of rear wheels for the 24 inch Victas that have come apart on the join. Obviously this was a problem from the start as I have had many wheels that must have been repaired by the dealers. They had big staples about 2 inches long holding them together. I'm wondering if anybody has any thoughts as to how I could repair the ones I have here?
NormK #115695 19/06/22 12:20 PM
Hi Norm
I haven't repaired a wheel like this ,just usually replaced the wheel.
I know there is a product called Rubbafix that looks good in the Video but no idea on how expensive it would be.
I have heard of someone that was going the mould some tyres up for the 24 but never heard if it worked.
If it was me I'd probably try holding the tyre on with Araldite as that will hold 75 kg and also fill the gap with Araldite,
I've used Araldite on black vinyl and mixed in a little black paint with the 2 part glue so it matches in a little better.
https://au.rs-online.com/web/p/fillers-putties/0692851
https://vimeo.com/282732075
I have had wheels like this that were drilled in the centre of the tread and every couple of inches a long self taper screws
down the rubber tread into the steel centre (on an angle so the self taper comes through the sheet metal.)
The head of the screw is below the tread in the tyre .
A cheap fix will look a little rough sometimes.
Not sure if anyone else has successfully repaired this problem without replacing the wheel and the wheels will still look standard.
NormK #115696 19/06/22 01:08 PM
Seems like the rubber has contracted and maybe a sign it's well past it's use by date. That's probably off an early 24 frame and reached 50 years of age.
Can you order them as a part? Otherwise, scavenge them off of Victa Vacs or other Super 24s and 600s with munted frames.
Nice array of metal tools in the pic BTW.
NormK #115698 19/06/22 01:53 PM
G’day Norm
Not something I’ve had to resolve with these but I have had a couple of other similar situations.
A bushie type fix would be to make new tyres either by wrapping thick belting around a hub and fusing it or cutting the correct size out of an old earthmover tyre, half a tyre a side and heating them to force them over the hub then using retread bonder to stick the two halves together.
In my experience you need newish rubber to do it, the older ones lose their elasticity and won’t come back to the correct shape. There’s also stuff called block or blocking rubber. I’ve cut “tyres” out of that too.
Ironbark
NormK #115706 19/06/22 07:42 PM
A kiddie bike tyre filled with emergency tyre mender stuff you get in a can?
NormK #115708 19/06/22 08:43 PM
I may try using a worm drive clamp around it to see if that will pull them back together, then work out to hold them in place. Maybe some Sikaflex product might bond them together
NormK #115715 20/06/22 08:35 PM
Maybe easier to change the wheels ,MTD have 12 inch wheels about $15 a wheel but may be difficult to find
in Aus ,I have 4 of them also seen bike trailer wheels with pump up tyres and they are about 12 inches.
NormK #115716 20/06/22 08:48 PM
Hold on, I recall the rear wheels on the fully imported models with Victa labelling printed on them like the Thunder and Hurricane (?) have the same size rears on them.
NormK #115717 20/06/22 09:14 PM
I think if I can't repair the wheels I have I will have to scrap a couple of these slashers. Front wheels I have used MTD wheels there but the back wheels are where I am struggling
unfortunately MF, those wheels are as weak as p***
What about wheelbarrow wheels?
NormK #115721 21/06/22 12:57 AM
Hi Norm, try some roofing screws through the wheel into the existing rubber to hold it in place and then Urethane to make up the gap. Don't bother with the clamp, as soon as you remove it it'll stress the join and come apart.
I would position the screws as per my updated picture.
NormK #115723 21/06/22 08:35 AM
Thanks BT,
I was thinking I might have to do something like that
7 8 9 10 11 12 13
14 15 16 17 18 19 20
21 22 23 24 25 26 27
28 29 30
18,120 Registered Users
Topics12,755
Posts106,798
Members18,121
