1 members (aitchey), 2,378 guests, and 1,760 robots.
NZ Moderator & Collector
The owners have just returned home after a few years overseas and were going to dump this mower as it wouldn't start.
Now, a mower this 'modern' is is not something I normally play around with but as it has some interesting features, I offered to have a look.
Firstly, the spark plug was cleaned and thankfully it produced a spark.
The air cleaner was fine and the engine had plenty of oil (though somewhat black).
The carb float bowl was removed and found to have a fair amount of varnish present.
After a quick clean with carb cleaner and fresh petrol, it fired right up.
Finally the blade was given a quick touch up, the oil changed, the front wheels tightened and then given a test drive.
Another one saved !
Mower Details:
22 inch, 3.5HP Briggs & Stratton Engine
Manufactured in 1999 by the Murray Ohio MFG Co.
Assembled in Lawrenceburg, Tennessee, USA
(The handle has been replaced in the past with something far more substantial than the original.)
Alan
Very nice mower Alan
Quite an interesting and nice and simple design for a SP mechanism, much like the early Rover systems.
I think it could very well be older than 99, the motor is a 'Max' engine - produced before the quantums which came out in 1990 ish.
The motor could very well be a 1989 - remarkably preserved if it is
Tyler,
Just had another look. I assumed the mower date of manufacture was 3rd January 1999 (1399). Perhaps they use a different system.
As you said, the engine is earlier - 1988.
All very intriguing, an engine swap sometime ?
Alan
Americans and their Front wheel drive, I have always wondered how effective that would be...
I think the way you read it is its a 9-22 651
Made 1989 (9), its 22inch (22) and 651 is the model
If what they say here is correct, then it would make sense it is an 89 as its the last of that model designation system
https://www.mytractorforum.com/threads/murray-model-numbers-and-doms-explained.145127/
Its in good condition for a 32 year old mower
Wish Australia imported smart self propelled mowers like this, but we insist on troublesome finicky gearbox models. Probably set up to drum business for the mower repairers. Wouldn't surprise me.
There was a particular shade of more golden sunset yellow the Rustoleum offer in the U.S but in Australia? No!
Of course available in NZ at Bunnings(!).
Retail is pathetic and weak in Australia. Your supermarkets walk all over ours too.
Yes it is a 1989 model and Briggs engine verifies this as it is a late 1988 build. It typically takes a month and longer before the engine get install by the mower's OEM.
18,145 Registered Users
Members18,145
