0 members (), 1,963 guests, and 549 robots.
Bushranger cylinder mower
Acrher Chainsaw Chain
by AVB - 21/01/26 09:00 AM
Model number - where is it?
by Koii - 12/01/26 12:06 PM
Sanli Redback Ret Spring
by NormK - 22/01/26 02:05 PM
by NormK - 21/01/26 09:55 PM
Rover Thoroughbred Model 85
#112155 21/05/21 10:14 PM
As some of you guys have probably worked out, I am always on the look out for stuff I need (or will need in the future ... honestly rolleyes)
Here are a few of the latest things I have seen
Autobarn have some PowerG tools out on clearance for $10 apiece .
https://www.autobarn.com.au/ab/Auto...LED-WORKLIGHT-1600LM-SKIN-ONLY/p/TO31171
https://www.autobarn.com.au/ab/Autobarn-Category/Brands/PowerG/20V-CORDLESS-AIR-COMPRESSOR/p/AC66259
https://www.autobarn.com.au/ab/Auto...0V-CORDLESS-HEAT-GUN-SKIN-ONLY/p/TO31170
Have been trying to avoid Chinese garbage on principle, but these actually seem good quality. 5 year warranty as well
These fit Aldi xfinity 20v - which are out in a week or so in a special buy.
As a heads up: it is very easy to modify the light to fit other batteries (such as XU1 and Ozito 18v) with the ability to switch the pins into other holes.
The compressor has the pin mounting screw holes tapped, but you would have to drill slots.
The heat gun is more difficult to modify and if you open it up, make sure you see where the spring went... oops.
Light is amazing - amazing amount of power. 2 intensities, ran 40 minutes on a 2.5ah battery and showed no sign of being about to run out.
Air compressor has a digital read out, a low pressure outlet and high pressure outlet which run independently.
Haven't tried the heat gun yet
They run fine on 18v (since the guts of both are same)
On another note, check your local repco clearance table for Kromex tools; they got a tonne of them when GPC bought out Covs. Taiwanese (which is at least better than chinese) and some of the prices scanning are pretty good. 86c for most pin/centre punches, $3 for cold chisels, socket rails (with sockets) around the $10 mark
Tyler #112156 21/05/21 10:29 PM
You know how to find the steals Tyles.
My Aldi 4L cordless air comp has given up the ghost and even though it has the balance of warranty left, I might just get the $10 one. You have to wait for the tank to fill up which takes forever. I'd rather one that just continually pumps.
Heat gun might be useful, although I already have one that plugs in and it's a good one -again from Aldos!
I will be going for a drive this weekend.
Tyler #112157 21/05/21 11:11 PM
MF, this one wont substitute for an air compressor as it has no tank. And I warn you - it isn't quiet.
But it works well for what it is
Tyler #112158 21/05/21 11:36 PM
Sigh alright better chase Aldos up.
Tyler #112480 16/07/21 11:44 PM
Was at repco the other day and found that they had Molybond 2.5kg antiseize out on clearance for $12 a tin.
Its a big yellow tin "Molybond GOG" - seems like regular copper based antiseize with a lot of MoS2 (Molybdenum Di sulfide) for anti wear. Supposed to be for heavy duty operations.
Not sure what the price was before clearance but knowing Molybond, it can't have been under $100 for 2.5kg
Been a few years since they stocked it as a regular item, and was on clearance for $40 for a while so stock is probably low
Worth checking your local repco
Tyler #112481 17/07/21 12:37 AM
Hi Tyler,
had a look and all I could find was Molybond 2.5 engine and gearbox additive in a yellow tube for $21 on clearance.
Tyler #112482 17/07/21 01:25 AM
MF, a good 60% of repco items are in store only. Their online one did have nearly 10000 items at one point, went down to 3000 now back to 6k
Tyler #113269 11/11/21 01:52 PM
Just letting everyone know Repco have the Gregory's Small Engine 2 manual out on clearance. $29 online, 23.20 in store
Covers Victa PT, Briggs incl Quantum, Stihl saws and trimmers like 009 and fs81, a few old mac chainsaws and eager beaver and Suzuki Rover 2 stroke
If you have an RAC card (or NRMA, etc) it ends up being $23.20. But the only way it will work is in store. If you order delivery or click and collect it is $29
1 member likes this: N1KK0
Tyler #113271 11/11/21 04:08 PM
Repco's Clearance section is a very good place to find ridiculously marked down gear - the problem is that it's a terrible website in terms of knowing whats actually in stock at any nearby Repco stores. BUT if you're happy to sift through it (6200+ items at present with very limited sorting abaility) you can find some amazing buys - might have to check my local again now. ;-)
https://www.repco.com.au/en/clearance/c/2538381394
Tyler #113272 11/11/21 06:58 PM
N1kko, it is a pain to navigate. I have made a .bat file with the things I want in it, then have a list of stores, select store then run the .bat file in chrome and it opens up all my items, check whats where, then close them all and put in another location and start again.
If I was more computer literate I am sure there would be a better way.
A few months ago I got 3x water manifolds for Holden Camira, normally 150+ each, repco clearance for $30
Tyler #114055 09/02/22 02:39 PM
Repco knocked a significant amount off some of their clearance stuff last night.
20l 5w30 full syn magnatec now $32 (1.60 per L) https://www.repco.com.au/en/oils-fl...-5w-30-engine-oil-20l-3396957/p/A5434158
Shell Spirax ATF X 20L (is a low visc one for newer cars - eg toyota ws rated oil) $52 https://www.repco.com.au/en/oils-fl...spirax-s6-atf-x-20l-300012932/p/A5369781
Valvoline Synpower Euro 5w30 (skoda, vw and others) $13 https://www.repco.com.au/en/oils-fl...r-5w-30-engine-oil-5l-1184-05/p/A9530469
Lots of air tool sets for $20-50 each - don't know how good they are https://www.repco.com.au/en/clearance/c/2538381394?q=%3Arelevance%3Alevel1Category%3A1862917853%3Alevel2Category%3A1862917867 (just copy and paste this one. If I take out the bits after the ? it doesn't link right)
Tyler #114952 15/04/22 01:25 AM
Tyler #114957 15/04/22 10:01 AM
I wanted a couple of cans of Start Ya Bastard but still listed at full price
Tyler #114963 15/04/22 02:35 PM
Seems to be out a little cheaper, but not enough to make it worth while
https://www.supercheapauto.com.au/p/nulon-nulon-start-ya-bastard-350g/13168.html
Tyler #114967 15/04/22 04:47 PM
Makes me cry, a few years ago I got 4 big cans for $7 each at R&E Auto just up the road from me
Tyler #114971 15/04/22 05:06 PM
Yeah I don't think it's worth buying any more a spray bottle with petrol does the same thing 90 percent of the time,
the only time the ether is better is when the valves and seats are little rusted.
Tyler #114972 15/04/22 05:11 PM
My morning breath will start a Cummins.
Moderated by  Bruce, Deejay
17,805 Registered Users
Topics13,058
Posts107,236
Members17,805
PHP: 8.3.28 Page Time: 0.114s Queries: 51 (0.101s) Memory: 0.7140 MB (Peak: 0.8142 MB) Data Comp: Zlib Server Time: 2026-01-23 05:17:34 UTC
