1 members (Red Rum),
3,351
506
Hey All picked up a replacement super 24 to replace my tired one well, until i give it a re build. the new mower has the 1980's side start full crank engine with low compression cylinder head. so its a super 600 ... anyway found to be completely gutless why they ever introduced those heads ill never know ( although they have a nice tune) so off with the old head and on with a power plus head along with a hone and some new rings that should give it some extra kick . tell me fellow victa lads what did you make of the side start full crank engines ? yay or nay .... also if anyone has a spare 550 cowl with the grill covering the flywheel and the cover for the exposed coil im currently seeking one  cheers all tomo
Posts: 1,819 Likes: 6
Yay.
I like the side starts. Some people do not like the plastic starter housings, there is an alloy one that was fitted to some models. I have only ever seen one or two busted plastic ones and the evidence usually points to a faulty fit or similar.
As for the cowl. I got a regular cowl off a series 80 with the coil check out, they usually had the plastic tank on top with the bolts down in the deep dark holes and the bolts rust and all you can do is drill them out to get the tank off. I got one of those and then trimmed up some mesh to go up in the underside of the cowl and pop riveted it from the top. Trial and error as you go to make sure you dont run into any clearance issues. Was just some stamped out sheet metal with round holes in it. Ive got the machine back here at the moment, if i think of it i will get a pic.
You could also get one that has the tank stuck on it and just hack the tank off and not worry about the rusted bolts. Would look a but rural.
Posts: 510 Likes: 1
I use these alot on my steep block. I have rebuilt 4 of them, I will attach some images. I will put a side start engine off a domestic mower on them. I prefer the side start to the top cowl type starter. With a decompressor they start quite easy. ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2012/08/full-4730-7600-hjk_005.jpg) ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2012/08/full-4730-7601-hjk_004.jpg)
Good stuff.
If you ever find a stuffed 24 with a good blade disc, im looking for 2 discs. Will take 3 if i can get em.
Id buy new ones but at $160 a throw for soemthing i dont really need its kinda hard to justify.
hey there, nice fleet ! must give my 3 a coat of paint and make them like new. constantly coming across the 24's but it seems the one thing that is missing is the blade plate. I had power issues with my side start turned out to be that the belt was too tight. i rather like the 70 series full crank rather than the side pull not sure why. Recently replaced the front axle on one of mine turns out you can get them new $170. cheers , mitch
Posts: 510 Likes: 1
Mitch, I forgot to mention that I spin the carby around so the snorkel comes out the back and flip the primer cap, no rules though. I didnt know you could mix and match heads, I will keep that in mind.
Rob, I am in QLD and these things very rarely pop up, I see them on ebay in other states. I have no blade plates. In one of the pics you'll see I ve put 250mm trolley wheels on the back instead of the 300mm originals. That is my lowered version. Parts are scarce. Cheers
Hey mark, i noticed your snorkels in your last post, I am rather obsessive when it comes to my mowers i like original - it annoys me at times. the original super 24 with the side pull ( super 600 ) the snorkel came out the rear and ran up the right hand side of the handle i shortened a throttle cable to suit and got a rubber bend to suit came out on vc mustang models with the remote primer fitted. these cables can be shortened at the control end the black fitting on the cable that screws to the air filter housing can be wound down the cable. Parts are rare down here now however in saying that rear wheels and rear wheel bushes front axle's are still available as they are still the same on the current Mastercut 600, a little pricey but they do up really well. love ya nice white handles! have you had any issues with them cracking around the mounts ? And yes their is a High compression head available if you can find one for both power torque and full crank engines original super 24 motors had them. cheers, mitch
you may also find this handy Belt tensioning for the super 24 under ' mower frames' in the forum list i found it handy!
Posts: 510 Likes: 1
Mitch Sorry about the original side of things, I have used what ever I had to get them useable. I did ditch the old tube type snorkels with the 2 paper tube filters down the bottom. I prefer to to see filter up on the handle out of the dust.
The handles do snap down the bottom, I have welded flat plate across one break. On another I tried a different trick, cutting away broken pipe and sliding neat fitting pipe over the top, then pop rivets to hold. Some of the handles where rusty white when I got them, decided to make them white again, why did they go with white in manufacture? My thinking was the handles would stay cooler in the sun???
I have had lose belts before ,the cord gets ripped out of your fingers. Some of my tentioning stickers on the frame are still legible.
They are a poor mans ride-on I know and big lugs to push around. But, I think they are well balanced, good for getting under fences/trees, they have a high cut & slash high grass, also if you hit something the blades will swing or belt will slip protecting the shaft. (I have broken blades) With the pulley size at the front the engine dosent have to work as hard. They have a lot going for them. Cheers
Hi Mark, the white handles may have something to do with the Victa colour schemes for that particular period...My Tilt-A-Cut also has a white handle; whereas later models had the black. Here's a pic:
Posts: 510 Likes: 1
G'day Darryl, Yep, colours look the same. Nice tilt-a-cut. I have always wanted one for some reason, not sure if I would use it a real lot. But like the idea of them. Had a chance to get a good one for $60 once. Thanks
Hey mark, thats how my first super 24 was bits and bobs to get it useable. the twin filter setup normally had a plastic tube up the handle, if you come across anymore id be interested in them i must say i would love to give my 24's a complete re paint in original colors of course. havent seen many that have been restored. call me crazy but i have a brand new ride on and we still mow 2 acres with super 24's cheers mitch
dont s'pose the blade plates are the same on smaller 550's ? never seen a 24 yet to know the difference except for pictures
they are bigger as the 550 iS A 22' cut and the 24 is 24' cut
The 550 is pretty much the standard victa disc but thicker with the super 600 blades on it to get the extra couple of inches.
The super 24 blade has 4 mount holes in a square pattern.
I did redrill one blade plate to take 4 x modified rover ride on blades. Worked OK but was a bit vibey. Wont bother trying again. Well i might if it comes to me how i can do it more accurately without making up some labour intensive jig. I took as much care as I possibly could.
Two of the machines i have here the blades have been left loose and the blade bolt holes are flogged out.
I think i have 6 machines here at present.
Posts: 510 Likes: 1
Vccomm, I have some shots here of the super 24 blade disc. ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2012/10/full-4730-8111-untitled.jpg)
Heres the worst disc. No sure how well you can make it out in the pic. One sides welded up, the other the nut is nearly pulled through. ![[Linked Image]](https://www.outdoorking-forum.com.au/forum/uploads/usergals/2012/10/full-4181-8200-8oct12_003.jpg)
thanks guys , now i know . the ones here do look bigger than a standard disc though and bigger blades yes
Posts: 349 Likes: 4
Another 24 thread with a guy worried that the belt was too tight causing power loss.
Lots on this forum about 24's.
Jeff
Posts: 8,216 Likes: 235
My mate cooked his a couple of days ago, swears he didn't straight fuel it but the spark plug told me a different story. Brought it over yesterday, hone and new set of rings and away he went a happy man again
Posts: 4,675 Likes: 165
G'day NormK, sounds to me he needs to have a dedicated two stroke fuel tin clearly marked. That's why I fear selling two strokes to anyone because we no longer have a two stroke mower culture where it's a given that you add little two stroke mix to the fuel. We've become like the rest of the world now.
Posts: 2,727 Likes: 220
G'day Norm and Mf
The first thing I notice is the fuel primer rubber is softer than a marshmallow when people straight fuel these mowers ,then just feeling the fuel in your fingers you can tell there is no oil in the fuel and usually the fuel colour looks wrong ,the plug check is worth doing too .
Cheers Max.
Hi Max, He has been using 2 strokes for years and he has had this 24 for probably 5 years. The fuel was blue and he insisted it was 2 stroke fuel but I'm never sure if people realize they have goofed up and quickly change the fuel in the hope it might save the motor. I have been fixing this mates motor bikes and mowers for over 15 years and in that time he has not advanced one little bit with his mechanical knowledge. Still a good bloke though
Being a good bloke won't magically protect an engine from a straight fuelling. Surely he knows how vital it is to mix oil into the fuel by now. What do you look for on the plug to indicate straight fuelling?
MF, when I was undoing the plug it squeaked and once out it was completely dry, the thread was dry as and the plug is a very light brown colour, not a hint of oil on it anywhere. Pull a plug out a 2 stroke that has correct fuel and you can see the difference immediately.
Got it Norm. Thanks. Makes sense. You must catch a lot out.
Topics12,780
Posts106,888
Members18,248
