3 members (MowingManiac, Brad_C, 1 invisible), 414 guests, and 661 robots.
by NormK - 01/12/25 05:15 PM
Victa 24 with PT fitted
by NormK - 05/12/25 09:55 PM
Page 6 of 6 1 2 3 4 5 6
I think if it was me deciding on what motor to use it would be the one that's the easiest and the quickest to fit Norm.
Yes Max, that is what I will do, I can try the PT idea some time in the future when I have play time.
Anyway this is my way of doing a pulley for the F/C. I think the pulley that came with the base may have originally been off a F/C but had been bored out to 7/8inch and a Rover blade boss welded to it. I cut the boss off, then turned a F/C boss down to fit the 7/8th hole, heated the pulley and pressed the boss in so now it fits straight on the F/C shaft. At least this gives me an option to make pulleys up for the ones I build in the future
Hi Jeff,
Many moons ago when you were setting up the PT on your 24 I came up with a measurement for you from the underside of the base to the belt. Do you have any idea where I can find those posts, problem is there is so many posts regarding these 24 it is difficult to find them. Might have to go and buy another one so I can measure it, there is 3 kicking around at the moment but they are all a fair drive from here
Hi Norm
The pulley and boss look solid now ,I can't see the pulley slipping on the boss especially when the crank nut
should lock the two together .
Not sure if this is what you are looking for Norm.
" the measurement from the deck to the top of the belt is 34mm"
https://www.outdoorking-forum.com.au/forum/ubbthreads.php/topics/45373/2.html
Thanks Max, exactly what I was looking for. Yes the boss should hold no problems, with the pulley spit hot it still took 10 tons to push it home
That's the right measurement. It worked
out pretty well too
No belt issued at all
Jeff
17,724 Registered Users
Topics13,034
Posts107,118
Members17,724
PHP: 8.3.27 Page Time: 0.060s Queries: 26 (0.053s) Memory: 0.6454 MB (Peak: 0.6948 MB) Data Comp: Zlib Server Time: 2025-12-14 12:26:59 UTC
