2 members (Bruce, auProspector), 1,466 guests, and 946 robots.
Page 3 of 4 1 2 3 4
G'day all
The 200 mm slack in the starter before it catches can be made better if using a later starter Norm ,the ones
that have a steel ring that holds the starter handle when retracted come out 100mm then catch the crank.
I had a standard PT the other day, the starter was 300 mm before catching the crank and it was a pig to start
so I changed the starter and it was easy to start but I can see the mechanical advantage of these starters not
so great. If I spin the motor over slightly to get the starter in a better position the slack in the cord goes down
to 80mm.
Having the starter handle mounted on the handle bars with a longer cord might be worth trying but I would change the starter
first and fit the longest cord possible with the starter handle in the normal position.
Thought I would be able to get this pos sorted but I have to give up they are garbage and not worth wasting any more time on.
Hi Max ,
These later type starters interest me
Our PT 24 originally had a starter that definitely did not engage early
Assuming it was worn somehow we changed it to a different one which was a lot better. However it still certainly had more than 100mm slack.
I have never seen one with a metal cord ring. What type of engine would they be standard on?
It seems I need one of these later engines. To get the bigger blade boss and the better starter.What type of mower are they on? I do need another 460 utility the chances of getting all that together in one mower are not high I guess. Any identifying cowls etc to look for?
I can see why a side pull has a mechanical advantage on the starter but a cup starter must surely be the same as a PT starter.
Jeff
Hi Jeff,
I got a reply from the bloke selling the pulley bosses, they weigh 400 grams the same as the heavy boss weighs but without the extra weight of the pressed pulley. With the restricted decomp and the heavy boss there is no attempt to kickback so you can pull it with confidance that you are not going to break your fingers. I believe the problem is a cup starter is spinning it directly from the center and the PT is pulling from the center of the conrod/big end and I'm sure this is what is causing the extra load. This coupled with the way the motor is positioned on the base means to get an effective pull you pretty much have to pull it vertically.I have worked out how to start it with my right foot on the mower and heave vertically with every bit of strength I have, using my back to slingshot upwards to get it spinning fast enough to fire. I have heaps of the metal cord ring type I will swap one on the see if any difference is achieved. At least I know it can be started but it is at the utmost of my strength ability to get it going and I can still lift mowers up onto the bench so I still have some strength left
Hi Jeff and Norm
The steel pull cord guide is on the previous page (4) Jeff, the first 2 images I posted one has a grey plastic top the other is the red top,
any model with that type of plastic top will have that starter.
https://collection.maas.museum/object/319768
We know a little more weight fixed the kick back problem and the full crank is not as difficult to start but these PT's
are missing half a crank compared with the Full crank and that means the PT is already missing 1000 grams of spinning mass
which is the same weight as a tow ball.
If it was me I would be buying a tow ball for $2. at the wreckers and machining the threaded part off the tow ball
then drilling and taping the tow ball so it threads onto the crank or just drill a hole in the tow ball that is bigger
than the crank thread and then weld the crank nut to the tow ball. That's probably 600 grams more.
The 460 Pro utility is the only model that I know that will have the bigger boss Jeff but a lot of the Victa utility
mowers don't have the heavier boss.
The 460 pro doesn't have the steel ring starter cord guide but has a removable alloy guide but is still a good starter.
Hi.Max ,& Norm
Never thought about the half crank and full.crank issue but Max has to be right
At least a kg less spinning mass
Norm
I think you need to find more weight
Not sure about a tow ball . Might drag on the ground.
Ours with the side ways mount is just like a normal PT in the position of the pull cord but it is heavier to pull
I'll keep looking for a later model
Looks like any with the rounded cowl would be OK
They seem to be getting more expensive around here.
Jeff
Jeff,
I would love to find more weight but I have lost 15kg over the last 8 months. LOL I have no idea what the wire rope guides come off but I have dozens of them here, probably a 50/50 mix of them so they are not rare.
Max, I have been thinking of all those ideas and I had already thought about the towball so my idea was not that silly but I wasn't going to mention it here. Had also thought of welding a round 1/2 inch thick plate to the nut but then there is the issue of burning out the nyloc nut. The only other place I can think of adding weight is a stepped heavy disc welded to the top side of the heavy boss. All still adds up to what I have said for a long time is that this configuration is not fit for purpose
Hi Jeff and Norm
I had a look under a full crank (Super 600) and there wasn't a lot of room for adding weight but the tow ball
would only come down another 42 mm ,looked like plenty of clearance to me but I'm assuming the PT motor
is in the same location. It's just the ball end that is used the other half of the tow ball would be thrown out.
Max,
latest thought is making a heavy steel disc and threading it and using that instead of the nut, can make that any size I wanted as you can remove the nut/disc before you take the motor off so you can lift it through the chassis
Yes that should work Norm if it fits in ,it was the full crank that I looked at and the axle was in the way of installing a disc
but the PT having a boss the disc may fit on the other side of the axle.
Norm
I thought of making a big heavy nut too
How would you stop it coming undone without the nyloc. Already have the wavy washer . Might be OK . I have never had one come loose even the old models without the special washer.
Jeff
If I can find a block of steel I could dish/bore the center out so it could allow the nut to go back on, all these options
Hi Norm
You might be able to laminate something from say 3mm plate. Just turn up some round discs with a
centre hole big enough for the nut and washer and one the right size for the shaft
Have tp weld them all together around the outside but if they are all the same size they would be easy to line up.
Jeff
Hi Jeff, probably what I will end up doing, I have some 1/4 inch plate here. I have fitted one of the starters with the wire ring rope guide as Max suggested it is a bit better and if you carefully rotate the motor with the cord you can get it to pick up without the 200 mm slack. I also fitted a long cord but haven't tried it yet as it was getting a bit late last night
Ok latest idea is I have a 500 gram barbell weight, just have to work out how to fit it
Ok so that solved the problem, no starting issues at all now, the PT half crank does not have enough crank weight to get the motor spinning. Dead easy to start now but how many of them are out there that are put away in the shed because they are impossible to start
Hi Norm
So just changing the starter was the key
Great
Jeff
Hi Jeff,
I didn't try it with the new starter, forgot about that, It was the extra 600 grams I put on the nut. I welded the 500 gram weight to the crank nut and welded a big nut on the face of it so I can rattle gun it up. It burnt out the nyloc but I rattled it up with my big gun so it is really tight. Just wanted to prove that it would work. So if I get stuck with another one then if I couldn't find another heavy boss I would be looking around for 1kg dumbell weight and fit that, it certainly makes it much smoother that before as well, isn't banging so hard, feels so much better
Hi Norm
A dumbbell weight. They are cast iron aren't they
I would love to see some pictures
About a kilo is what it needs from a standard boss. Those dumbbell weights might be expensive if you had to buy one as I would.
Anyway good to see a success. This has been troubling is for a while now.
Jeff
Norm
I guess you could try one of those locking nuts that works by damaging the thread slightly. No nylon.
I think you could weld that up fine
Jeff
Hi Jeff,
I thought it would have been cast iron but it was steel and so hard that I couldn't turn it, just kept taking the edge off the tools. I remembered that the dumbell had been sitting under the lathe for years, never know when you might need something like that
Hi Jeff,
Here is the weight I used, must have been made of scrap iron, just so hard, nothing I had would touch it.
Thanks Norm
Hi Jeff,
now this machine is fit for purpose, it starts easily, a bit heavier than a standard PT but that is to be expected but to achieve this you need to add at least 800 grams to the crank. Not a problem for the factory to do it but they were obviously happy to sell these machines that were near impossible to start. I now need to find another one just to prove my theory. Good news is they can be fixed. I just have to keep on the lookout for small barbell weights
A dumbbell weight is a smart idea! You're using it for it's purpose, just not how people expect!
Good to hear the despair cine to an end thanks to exercise equipment!!
Hi MF, Norm and Max,
Even better news is that the weights are only a few dollars on eBay
The one I was looking at was cast iron with a steel sleeve and rubber coated
All of which you do not want
$3.00.
Our PT does have a slightly heavier pulley but nothing like 800g
It kicks a bit but not too bad
We are used to pulling pretty hard to start it
It can stay as it is for a while at least until I get to Eden next which won't be anytime soon
Well done Max & Norm in solving a very long standing problem
Jeff
Hi Norm ,Jeff and Mf
Good to see it worked out well Norm , I hope the quality of the metal weight is high quality and
doesn't fracture and explode at 3500rpm ,it sounds like good steel as it was blunting the lathe tool ,for safety
I would normally like to know the quality of the steel if spinning it up to 3500rpm .
Hi Max,
I would be more concerned about cast iron exploding, being a barbell weight I would expect it to be made from scrap metal and that means many sorts of metal in the mix. All I know is it just took the edge off a brand new carbide tip and all it did was take the paint off it The main concern was that it might have been too hard and brittle but as it is only spinning with no load on it it should be fine, besides it is up inside the bodyso reasonably protected from any flying bits
My instincts tell me as long as it's spinning true and doesn't strike something violently, it won't explode merely from spinning.
G'day Norm ,Jeff and Mf
As far as I know the barbell weights are made mostly from cast iron, I am also guessing it will be ok but I can't say I
have seen a cast weight welded to a crankshaft nut before ,cast iron is used extensively for flywheels so I can't
see a problem with the weight it's just the welding that needs to hold long term. .
https://www.tworepcave.com/4565/what-are-olympic-weight-plates-made-of/
https://en.wikipedia.org/wiki/Weight_plate
Hi
It would not be that difficult to turn something up from 12mm steel plate
2 thicknesses should do.
I have always been told not to try to weld cast
iron although I have a couple of times with reasonable results. Those weights I was looking at with the steel sleeve might be OK
Could weld only to the steel sleeve.
You are supposed to preheat cast iron I think
I don't think there is much of a safety issue
If the weld breaks the weight will just fall on the ground
I had blade disc fall off when I broke the end of the crankshaft off
It just fell on the ground . I didn't even notice until it appeared out the back of the mower
Jeff
Page 3 of 4 1 2 3 4
18,091 Registered Users
Topics12,750
Posts106,781
Members18,091
