1 members (zillh2004), 7,415 guests, and 1,876 robots.
Hey group.
So, has anyone found a solution that doesn’t involve drilling and putting bolts through to stop the handlebars from shifting when in use?
When I took my handlebars apart, something that appeared to be lead came out. I assume someone may have used it to pack them out in the past.
I have read about someone suggesting putting a coke can in and calming down around that... no luck.
Has anyone found a way on stopping the floppy bar syndrome? I was thinking some high density foam rubber?
G'day Scott
A coke can may not be thick enough ,I had mowers where people had cut a strip of 1mm or 1.6 mm sheet metal and
used that between the clamp also had a hacksaw blade put in one.
I've heard you just grind a bit off the back of one clamp.
Hi Scott,
I was thinking along the lines of something like 1mm nitrile rubber or any hard rubber of a similar thickness
Cumborah Kid, Betant, malo, joemowsbest, greenback
18,209 Registered Users
Posts106,867
Members18,210
