2 members (Buckets, Peter9231), 2,521 guests, and 173 robots.
by MikeDD - 12/02/26 09:45 AM
by Bruce - 16/02/26 12:06 AM
Rover Thoroughbred Model 85
by Bruce - 15/02/26 11:59 PM
by Bruce - 15/02/26 11:49 PM
by Bruce - 15/02/26 11:42 PM
by MowingManiac - 15/02/26 12:40 PM
Victa Corvette 4016
by Bruce - 10/02/26 07:53 AM
Cox ride on
by NormK - 04/02/26 08:14 PM
Page 2 of 3 1 2 3
Sounds like my one - same case, 3 sockets, 3/8 adaptor and extension.
Not meaning to be a pain, but Repco now have 30% off Coolant - https://www.repco.com.au/en/oils-fl...lon-premix-coolant-4ltr-pmc-4/p/A9721073
Same thing always happens to me - comes on special 10 sec after I buy it.
Mine doesn't have the 3/8 reducer. The oil arrived today. Better one than non. Very happy and thanks again Tyler.
What do you make of the STP oil additive? I bought another for $7 from the Reject Shop to pour in the LTD after being rather pleased with the improved smoothness in my Laser.
wce Offline
Hi MF and Tyler
Oil additives, now there's a large tin of worms to be opened. I think modern decent quality engine oils contain important additives and some oil manufactures claim additional additives can greatly effect the oils chemistry. It's purely an individuals choice to use or not.
wce
Thanks wce for your input.
I think I'll be returning the STP along with the dozen Purina duck and sweet potato gourmet cat food tins as Fontanelly is already showing signs she's over that flavour cat food!
I'll leave the Laser to be the guinea pig as it has several oils in it's sump already.
The only oil additive that made a huge difference to my motors was Bitron. One of the first things I noticed apart from a huge temp reduction on a hot day was the ache in the right ankle as I had to adjust my foot position and back off the pedal. Hard to believe but a fact. I used it for a number of years and then I could no longer get it. Another amazing example was the one for trans/diff and anything else you wanted to use it for, like drilling stainless steel. A mate of mine had a Falcon, XF maybe, and it would stall the motor when you were driving through a roundabout, foot off the accelerator and turning the power steering. All I had of that Bitron was about a teaspoon full, I put it in the power steering and bingo problem solved. Believe it or not
I noticed the temp guage sitting lower than usual as I was driving the other day NK. This was on a moderate temperature night but of interest non the less. The level rose to the usual temperature at one time at a set of lights.
It was sitting 3/4 if the way to hot the last time I was in heavy traffic on a hot day recently. It was getting worrying. It needs a new radiator I think. It will be interesting to see the difference on the long climbs on the freeway where it regularly gets beyond the half way mark. I have been told that the oil tends to get very hot in the Laser's Mazda B series motor, especially when the oil is getting close to being due for a change.
Hi MF, Norm and wce
Now the Camira is cooling system central at the moment. As I previously posted, I put in Nulon stop leak. Worked perfectly 3 drives then stuck the thermo shut and almost cooked it. I was standing at the side of the road shorting the thermo with fencing wire and smacking the housing with a spanner before it opened.
To its credit, even after flushing the leak slowed significantly and I haven't been worrying about it too much. Loses about 100ml over an hour drive. If I drove it every day, I would worry
Got all the parts to fix on clearance, so can't complain.
Replaced smaller thermostat housing ($11 instead $55), new tridon thermostat ($3.50) drilled with 2x 5/32in ? holes (can remember but sort of victa needle thickness size), reverse flushed and new coolant.
Goes up to a bit before half, thermo kicks in, back to 1/4. The problem is the gauges are known to give false readings, so I plan to run a test involving a multimeter, and a checklight. Checklight through thermo switch to see on off, multi between temp sender and ground. Check readings against gauge deflections listed in manual to see real temp.
My main back up is the knowledge that if it noticeably pings before 15 x10mmhg on the vac gauge, then its getting too hot.
I got the big thermostat housing base on clearance at repco ($35 is nicer than $212) and will install in december with new timing belt, and possibly one of my $5 repco water pumps if necessary.
Oil additives are a big can of worms. I have about 20 different sorts here I have either got given or paid under $10 for. Nulon worn engine repair does do what it says to a degree. Rislone oil stop leak works damn good - turned a briggs leaking its whole sump in a week to losing 50ml over 6 months. I have got other rislone, liquimoly and other ones I can't remember floating around.
You are one savvy shopper Tyler. I really need to learn to keep my finger on the pulse.
I'm sure some luck was involved though lol.
I really felt a buzz picking up the bottles of coolant and the 30 weight oil knowing I was getting a good deal on top quality products not easy to come by just walking into a store.
I also would never have known about the Nulon motor oil deal without your head's up, and likely would not have considered buying if you hadn't recommended it. Very grateful.
Regards the STP treatment, it is a unique set of circumstances that led me to try it. I had done an oil change with about four different leftover oils from different brands to get rid of them and it hadn't quite filled the sump -it was reading half way on the stick.
I came across it and thought why not make up the difference, I can always drain it. It did run smoother and felt slightly more peppy with throttle inputs but now just sounds normal.
It does seem to operate at a lower temperature as well.
I won't be using it in the Fairlane as that only has the Penrite which is an impressive lubricant in it's own right.
Seeing that SCA has lost the Bathurst sponsorship deal I wonder if their prices might come down a bit. As soon as Bob Thorn was out of the picture their prices rose significantly.
Repco sells items cheaper than SCA a lot of the time and I get far better service from the staff at my local store than the nearest SCA, although there is a guy at the SCA who the staff consult who is very good.
It also helps that they employ some nice helpful young girls who act professional.
Overall though it feels more impersonal than at my local Repco.
Quick note to say Repco has 25% off all clearance.
So again, sorry MF, the oil is now $4.12 per L.
Over next few hours I will post good deals
Regards
And you were saying it never goes below $5 lol?
Ahh well, would have been over the moon at that. Sometimes it pays to procrastinate.
PS just seen you added that extra post. Thanks will have a look.
Good alternative to SYB https://www.repco.com.au/en/oils-fl...rt-aerosol-350g-raenginestart/p/A9627137
Good price on Dex3 https://www.repco.com.au/en/oils-fl...transmission-fluid-4l-3381101/p/A9511192
https://www.repco.com.au/en/oils-fl...orcycle-engine-oil-4l-3384384/p/A5352007
Full synth 2 stroke, Castrol, JASO FD. Even better deal per L than aldi
If you are not as particular (or in my case retentive) with 2 strokes, this Castrol Activ JASO FC will be fine https://www.repco.com.au/en/oils-fl...engine-oil-4l-4100596-115238-/p/A9310996
Don't know much about outboards/ outboard oils but 4l shell is $16 https://www.repco.com.au/en/oils-fl...troke-engine-oil-4l-300012129/p/A9513945
Other castrol tcw3 oils for around $20/4l and one Valvoline one down at $4 per L
Bought 2 tubes of this last time. Not bad, but not high temp https://www.repco.com.au/en/car-car...sikasil-rtv-gasket-black-300g/p/A9560028
This stuff can be handy to keep around. https://www.repco.com.au/en/car-car...hite-e-pox-e-ribbon-putty-39g/p/A4240898
More to come
The sale is called the 'Sorry not sorry sale' with a tissue box showing V8 Super cars and Repco logo.
obviously taking the P out of SCA
Good on them
Would that Loctite epoxy be ideal for possibly patching exhaust/muffler leaks? Fairlane's muffler is leaking apparently.
Do you know of any exhaust diy repair products on sale/pending sale?
Can you give run down on what that 3/8 gearless handle is good for?
Thanks Tyler, great stuff.
Turbo timer, https://www.repco.com.au/en/in-car-...rol-diesel-turbo-timer-12-24v/p/A9623623
Bought 20 pair of these gloves last time, very good (but some fluro yellow just so you are aware) https://www.repco.com.au/en/safety-...loves/gloves-maxi-pro-sz11-pr/p/A9767499
A lot of the clearance stuff is gone now. When I originally found out about it, there were 10000 clearance lines. Its now at around 5800.
Will keep looking, but not much else for now I think
MF - all repco is 25% off till monday night
If the leak is at a seam, use this https://www.repco.com.au/en/car-car...-maniseal-exhaust-cement-145g/p/A5179300
If the muffler itself is rusted, use this https://www.repco.com.au/en/car-car...es/loctite-muffler-putty-200g/p/A3558126
Honestly, I had a 5c piece sized hole in the Camira muffler. I put a thick smear of red hi temp RTV on it as a stop gap. After a few weeks, I decided to see how long it would last
That was 18 months ago minimum
The 3/8" head is a ratchet head, but doesn't make the clicking noise. Does both directions and is really handy when in tight spaces (eg Briggs quantum bowl nut). A regular ratchet wont find time to latch to the next tooth before the end of the handle is hitting the air filter housing, but on this one you could undo a nut a fraction of a mm at a time.
One big final deal
Valvoline Synpower offer $20 cashback on 5l bottles. It happens that repco have 10w50, 5w30 and 5w40 synpower for $24.75
So, providing the $20 rebate per bottle comes back, it works out at $4.75 for 5l of motor oil
It says for Street Machine Of the Year voters only, but it never asked me for anything when I just submitted the claim. I did however vote back when voting was open.
I have 6 bottles over 2 transactions as I am sure I read somewhere max 3 bottles per transaction.
NOTE - Do not do more than 2 transactions with same credit card in a given day, or Repco site will think you have a stolen card.
Worst case I return them
https://www.repco.com.au/en/oils-fl...-10w-50-engine-oil-5l-1165-05/p/A9398490
https://www.repco.com.au/en/oils-fl...c-5w-40-engine-oil-5l-1155-05/p/A9398489
https://www.repco.com.au/en/oils-fl...r-5w-30-engine-oil-5l-1299-05/p/A9530471
Evening all
Had a good look through the black friday sales and cyber monday sales - mostly a WOFT. The only thing of note is 30% off penrite grease, and all fuel and engine additives which isn't bad.
However, the new repco catalogue was delivered today - not a great deal of specials either
From wednesday 2/12/20 they have Nulon 15w40 mineral oil 5L for $10. Limit 3 per customer (when autobarn have same offer its max 2).
For those who I haven't already bored with my oil comparison, Nulon is API SL, chock full of ZDDP zinc, good TBN (to cancel the sulfuric byproducts of 'blowby' gases) and has a very good shear resistance. It rivals SAE30 for use in briggs in my opinion; though you may use a tiny bit in temps 35 and above.
I have at least 8 bottles of this since I always stock up when I see it - good oil.
I would HIGHLY suggest doing a click and collect order on it as the deal comes live (midnight 2/12/20 AEDT) or at least before the stores open. Demand will severely outstrip supply. Autobarn have stock issues doing 2 bottles per person let alone 3.
For those of you who cannot get the nulon, Autobarn have gulf western 15w40 at $9.99 (2 per person) in store only. Note, this is a new formulation from GW with API SN which means lower ZDDP, and the TBN isn't as preferable either. I would comfortably use this one as flushing oil, or in a smoky old engine that is buggered anyway.
Most likely, it would do no harm to briggs either (since we know old ones will run on 200ml of tar for years)
Finally, if you must have SAE30, they have 30% off all motorbike and small engine oils. You'll get 5l of Penrite 30w for $30, or 5l of Repco 30w for $28.
Also if you are tempted to get the $11 penrite greenskeeper 2 st oil, just trump (haha) up the extra $2.33 and get the penrite MC-2st Semisynth. Very good oil for the price.
Page 2 of 3 1 2 3
Moderated by  Bruce, Deejay
The Todd, jtw37, Rod Browning, whodat76, HVP
17,854 Registered Users
Topics13,065
Posts107,272
Members17,855
PHP: 8.3.30 Page Time: 0.101s Queries: 57 (0.090s) Memory: 0.7448 MB (Peak: 0.8869 MB) Data Comp: Zlib Server Time: 2026-02-17 22:52:41 UTC
