1 members (aitchey), 2,378 guests, and 1,760 robots.
#10825 09/01/09 02:42 AM
I have just replaced the primer bulb in my Ryobi RWT285DS and now it runs for about 10 seconds and stops. Did I do something wrong?
David
I tried that but priming does not work then (the bulb fills with air). I think it is something else...
Did you replace the fuel screen in the carby?
Have you kinked the fuel line from the tank to the carby or has the fuel line have a pin hole in it or did you replace the fuel tank filter?
These could be some of your problems. cheers2
There are no kinks in the fuel lines. A pin hole is possible (there is an air bubble in the priming bulb which does not go away). There is no fuel tank filter that I can see. One of the fuel lines appears to be just pushed into the fuel tank without any nipple or filter. This line connects to input side of the priming bulb. The other line from the fuel tank has a nipple and connects to the bottom of the carby. The output from the primer connects to the top of the carby. I'm thinking that these two lines could be the wrong way around!
Thanks for your help. I'll replace the fuel lines and see what happens.
I have replaced the fuel lines and installed a new carby kit and spark plug (I was at the shop anyway). It is still not running all that well (it ran for about half a tank of fuel and then stalled). There is always an air bubble in the primer bulb. I'm out of ideas!
Anyone?
Anyone?
If you don't have a filter in the tank you will have problems all the time.
Below is a parts list of the tank, fuel lines & filter. cheers2
Weedwasp tank
Feeling inside the tank - the hole with nipple protruding has a filter. Obviously I didn't replace that. I'll get one of those now smile
I still think the lines are not connected correctly. Should this line go to the bulb or straight to the carby?
I cant tell from the diagram.
davidfnq,
Easy way to test if you have the hoses are on correctly is to only leave the hose that has the filter in the tank connected to the carby.
Then the other hose that goes from the carby to the primer put it on one side of the primer and then prime. If the fuel is forced out the other outlet of the primer it is in the correct position but if not put the tube on the other side and fuel should come out of the other outlet.
Did you replace the screen filter in the carby? cheers2
Thanks Buruce
I think I'm getting there. From your description, the fuel flows from the tank to the carby and then to the priming bulb. Is that correct?
I replaced everything that was in the carby kit. What does the screen filter look like?
Again.
david
David,
The filter in the carby is a tight weave mesh.
The fuel line goes from tank to carby and carby to primer then from primer back to tank. cheers2
I have pulled the carby to pieces a dozen times - I cant find any filter.
The current symptoms are that it starts perfectly but dies after 30 seconds. The primer bulb always has bubbles. There are no leaks in the bulb or fuel lines.
This is driving me nuts.
Thanks for all your help - I think I'm close!
David
davidfnq,
The screen is on the pump side (the one with the single screw in the cover) it is a hole about 1/4" in diameter with a screen in it. Remove and replace it as the mesh is too tight in the weave and fuel gets blocked causing it to reduce the fuel flow. cheers2
I'm in the process of doing this myself and have just posted some pics of mine in the photo section here
https://www.outdoorking-forum.com.au/forum/ubbthreads.php?ubb=showgallery&Number=10907&#Post10907
18,145 Registered Users
Members18,145
