0 members (), 2,932 guests, and 605 robots.
Hi Guys,
I need help to identify this old Victa Utility lawnmower of it's history, year, model, engine (2-Stroke?), Oil/Fuel Ratio, carburetor type, etc. I just bought this through Facebook for $20. I think this is a great project for restoration for my YouTube channel "Varietech". I believed this is a G3 type carburetor if I'm not wrong but I'm not sure what is the broken part off the carby hanging off the wire. I appreciate for any inputs. See attached photos. Thanks.
TheCarbyMaster
Hi TheCarbyMaster
Full Crank 2 stroke Victa engine 125cc utility, 25:1, G3 carby. The applicator appears broken, but are still avaible on ODK I think
Probably a 1972-75
https://www.outdoorking-forum.com.au/forum/u...1/brochure-professional-range-c1972.html
https://www.outdoorking-forum.com.au/forum/ubbthreads.php/topics/61969/catalogue-victa-1972-range.html
Just an addition to the above, I was wrong. The applicator is the little tension ring which hooks into the spring. I meant the connector
https://www.outdoorking-forum.com.au/engines...cr03318?zenid=gue7legrhhm1ni3j6617ash516
Unfortunately, its NLA through ODK. I would try some old mower shops. The throttle cable hooks through a brass pin, which slides and cuts off spark
You should probably invest in these gears as your ones may be worn. These operate the governor and are prone to slipping and jamming
https://www.outdoorking-forum.com.au/engines...320-060?zenid=gue7legrhhm1ni3j6617ash516
Tyler,
Thanks for the info! Yes It sounds 2-Stroke when I pulled the starter. I'm wondering where is the decompressor valve?
How is the throttle cable connected and how this broken wire (applicator) function (stop switch?)? I believe the wing on the top of the carburetor is for air vent (governor) but trying to figure out the throttle connection and this broken wire contact. Thanks.
TheCarbyMaster
Hi CM,
most likely no decomp valve if so it would be under the fan shroud into the head. The wire on the throttle connection is the kill switch wire
Hi NormK,
It's interesting to find out how the decompression works on this type of mower. I have a spare G3 carby which I can see where the broken part was. I'm still trying to figure out how this kill switch works and how and where is the contact. Attached spare G3 photos.
CM
G'day CM,
Yup, the deco valve is missing, and it's the NLA new 'long' type.
Easily picked up on FleaBay, and rebuild kits are available too; here's a 'how to' I wrote up on the rebuild: https://www.outdoorking-forum.com.au/forum/u...ssor-valve-rebuild-how-to.html#Post85918
Carby exploded diagram is here; https://www.outdoorking-forum.com.au/forum/ubbthreads.php?ubb=showflat&Number=11468
Shop manual excerpts are here; https://www.outdoorking-forum.com.au/forum/ubbthreads.php/topics/54967/victa-engine-parts-list-and-
manuals.html#Post54967
The contacts are the 2 brass parts in the connector. There is a plastic spring you can't see when it's assembled, that normally holds them out of contact. 'Earthing' connection is via the throttle cable inner, to outer, to cable clamp on the carby body.
Thanks Tyler,
I can see the decompression valve is above the engine, under the cowling. Sure I will invest on the gear trains.
CM
The engine number should give more info to get a closer build date.
18,144 Registered Users
Members18,145
