1 members (Commspares), 4,166 guests, and 1,913 robots.
#107671 06/08/20 03:19 AM
Hoping someone can help? I’ve done myself a mischief and have broken off the pulley bolt inside of the flywheel nut. Unfortunately the broken bolt is absolutely thread locked inside the pulley nut and neither heat nor cold with no amount of easy outing with remove it.
Does anyone have these parts I can purchase please?
Regards
GeeJay #107680 06/08/20 11:49 AM
You may have already had a go at drilling it out, if not to do it you will need a pedestal drill and vice as you need to be fairly accurate with the drilling, use a drill a size or two smaller than the bolt and run the drill through it, the aim is to get a hole drilled through a size that you can then run a tap through to remove the remnants of the bolt that is held in the thread of the nut. The other way is to drill the bolt as above, then using a hacksaw blade cut a slot through the length of the hole you have drilled, you need to cut deep enough so the cut is at the bottom of the thread in the nut, starting at the cut using a small screwdriver if cold chisel you are usually able to get the remnants of the bolte loose enough to remove, you can also put another cut opposite the first.
Whilst this does do some damage to your nut I have found in past experiences there was no effect on the integrity of the nuts capacity to do its job,
good luck.
Beech
GeeJay #107713 07/08/20 10:04 AM
Finally! After lots of effort and a few fail attempts it’s finally out. I can’t believe how thread locked the bolt was.
Firstly I I drilled and tapped the bolt from the rear with a 5/16 UNC high tensile bolt and attempted to rattle the offending bolt out but only mananged to strip the newly cut thread.
Then I retailed it with a 3/8 inch UNC thread and screwed a bolt in the and then welded it in place and attempted to rattle it free and Lyra managed to break the weld.
Finally after plenty of heat and the largest possible easy out and an 18” shifter did it thankfully break free. Woo hoo! Happy days!
Hksmonaro, Kellogs75, Gubba, fiercertonks, TMP
18,187 Registered Users
Posts106,827
Members18,188
