1 members (Buckets), 6,773 guests, and 250 robots.
#106144 17/05/20 08:45 PM
Hi everyone
Quick question what is the best way to clean the aluminium head on my Rotomo engine?
Virtually impossible to get anything between the fins the scrub them?
Hi Lorenz,
I usually hit it with generous amounts of degreaser, let it do its thing and then go nuts with the pressure washer.
However, I've just sent some alloy bits away for vapour/aqua blasting, including a head. I'll post results in a few days when I collect them, but from what I've seen, it's a great process.
Hi Lorenz , Mystyler
I've heard of a few products that work well for removing carbon etc from alloy heads ,baking soda or walnut shell as a blast media will
also clean alloy and Chemtech Blitz Aluminium Cleaner or an oven cleaner product should work .
I have used the baking soda method and it did a good job, bit slow but on a small head it wouldn't take too long
I am looking at one of those small hand held sand blaster guns, I have a mate that used one and the head was like new. uses playground sand from Bunnings. only around $45.
https://www.ebay.com.au/itm/Portable-Sand-Blaster-Gravity-Feed-Gun-Media-Etching-Surface-Cleaning-Extra-Tip/183251976047?hash=item2aaaab3f6f:g:jTgAAOSwseFcKyC8
all the best
Paul
Thanks for the advice gave some oven cleaner a go because that's what I had laying around. It works well to remove all the carbon and dirt but does leave the head looking a little dull. Will give it a quick go on the buffing wheel and see if that brightens it up.
Hi All,
Lorenz a Steelo pad can be used to polish alloy. (to start with)
paul_c ,I don't like those sand blast guns ,you go through a lot of sand just cleaning a small item and with that gun you would
be forever putting sand in it ,I prefer the cheaper gun that can draw up as much sand as you need or I have seen second hand
blast cabinets for $50 and portable sand blaster units second hand for $50.
Hi all, this is the result of vapour blasting the head.
1 member likes this: Lorenz
G'day folks,
be forever putting sand in it ,I prefer the cheaper gun that can draw up as much sand as you need or I have seen second hand blast cabinets for $50 and portable sand blaster units second hand for $50.
Yep, I agree. That top mounted sand reservoir is clumsy all round.
I have 3 'sandblast guns'; the 'big one' like maxwestern's, the 'medium', and the 'mini'. They all have their applications for specific jobs.
Medium
Mini
Mini
Lots of interesting techniques when cleaning the heads. Mine turned out pretty good with the oven cleaner and some auto sol polish. I could see how sand blasting or vapour blasting could be beneficial as I had trouble getting the very bottom of the fins clean.
vandea05, tack, Sabre, Claudia1, AllanStevens
18,224 Registered Users
Topics12,775
Posts106,876
Members18,225
