2 members (bigted, Mikey.Menace), 1,066 guests, and 305 robots.
Victa 24 engine pulleys
by NormK - 19/10/25 08:49 PM
Re rotomo crankshaft.
Rotomo crank shaft
Oregon corded chain saw
by NormK - 05/10/25 11:12 AM
Out there cutting again.
by NormK - 22/10/25 09:06 PM
The Rover Pro-Cut Chronicles
by DFB - 19/10/25 09:36 PM
Rotomo crank shaft
#105577 25/04/20 07:20 PM
QSR
Offline
Hi All,
I've got a B&S 2hp motor that I'm looking to rebuild and need help with identifying the model and finding a parts manual.
This is stamped on the engine cowl 60102 0302 01 6906091
QSR
Hello QSR
Engine Operator and Parts List are available here...
https://www.briggsandstratton.com/na/en_us/support/manuals.html
I have checked and these manuals are available.
Any problems, let ius know.
QSR
Offline
Hello QSR
laugh I forgot to put the 0 infront of the number, was wondering why it didn't find anything initially.
QSR
G'day QSR
We know who used this engine spec. in Australia ...
https://www.outdoorking-forum.com.au/forum/ubbthreads.php/topics/84251/model-40-14-reel-lawnmower-c1961.html
Maybe this was a Scott Bonnar engine ... ?
Also being a '69 model the trim number needs to 99
Format number as 060102-0302-99
G'day folks,
I find this version of Briggs' manual/parts list search site a bit easier to use; http://bsintek.basco.com/MDEXResultsPages/default.aspx
It's much better at searching from incomplete model numbers.
QSR
Offline
G'day QSR
Yep it's a scott bonnar motor. Pull most of it apart today and aside for the old oil and bad fuel the motor looks to be in good nick! It has the crosshatch honing marks in the bore not sure if it's from factory or if the motor had a rebuild in it's time. Pictures attached. When I rebuild it should I give it a light hone or leave bore as is?
QSR
Nice nick QSR.
If that bore is as good as it looks, I would measure up, check ring gap then on a good result, deglaze with a ball hone.
If the rings are within gap spec & tension, I would lightly dress the rings on a surface plate/glass with finest wet n dry to remove any edge - or replace.
Have you plasti-gauged the big end bearing?
6 7 8 9 10 11 12
13 14 15 16 17 18 19
20 21 22 23 24 25 26
27 28 29 30 31
Maudebs, Greenarrow01, stkarl, Stannyboy, yaapeet30
17,640 Registered Users
Topics13,009
Posts106,972
Members17,641
PHP: 8.3.26 Page Time: 0.025s Queries: 32 (0.018s) Memory: 0.6563 MB (Peak: 0.7198 MB) Data Comp: Zlib Server Time: 2025-10-24 13:07:35 UTC
