1 members (thomas18), 8,277 guests, and 1,196 robots.
#105577 25/04/20 07:20 PM
QSR
Offline
Hi All,
I've got a B&S 2hp motor that I'm looking to rebuild and need help with identifying the model and finding a parts manual.
This is stamped on the engine cowl 60102 0302 01 6906091
Hello QSR
Engine Operator and Parts List are available here...
https://www.briggsandstratton.com/na/en_us/support/manuals.html
I have checked and these manuals are available.
Any problems, let ius know.
QSR
Offline
Hello QSR
laugh I forgot to put the 0 infront of the number, was wondering why it didn't find anything initially.
G'day QSR
We know who used this engine spec. in Australia ...
https://www.outdoorking-forum.com.au/forum/ubbthreads.php/topics/84251/model-40-14-reel-lawnmower-c1961.html
Maybe this was a Scott Bonnar engine ... ?
Also being a '69 model the trim number needs to 99
Format number as 060102-0302-99
G'day folks,
I find this version of Briggs' manual/parts list search site a bit easier to use; http://bsintek.basco.com/MDEXResultsPages/default.aspx
It's much better at searching from incomplete model numbers.
QSR
Offline
G'day QSR
Yep it's a scott bonnar motor. Pull most of it apart today and aside for the old oil and bad fuel the motor looks to be in good nick! It has the crosshatch honing marks in the bore not sure if it's from factory or if the motor had a rebuild in it's time. Pictures attached. When I rebuild it should I give it a light hone or leave bore as is?
Nice nick QSR.
If that bore is as good as it looks, I would measure up, check ring gap then on a good result, deglaze with a ball hone.
If the rings are within gap spec & tension, I would lightly dress the rings on a surface plate/glass with finest wet n dry to remove any edge - or replace.
Have you plasti-gauged the big end bearing?
18,192 Registered Users
Topics12,767
Posts106,835
Members18,193
