0 members (), 5,309 guests, and 595 robots.
by NormK - 01/12/25 05:15 PM
by maxwestern - 08/12/25 05:51 PM
Victa 24 with PT fitted
by NormK - 05/12/25 09:55 PM
by NormK - 05/12/25 10:14 AM
Lectron Generator Fuel Pump
Hi All,
Not sure if I have described it correctly but just had the blade carrier on my Honda HUT216 fall off - on inspecting I found that the issue was the the raised tongue/ridge of metal on the engine's shaft, had somehow broken off, meaning that the blade boss wasn't held in place and it and the blade carrier would just spin.
A picture is worth a thousand words so:
[img]https://photos.app.goo.gl/nMZECPZ6MpAXJ2Vy5[/img]
[img]https://photos.app.goo.gl/NC17NiNJkN1rq6L6A[/img]
Any ideas on how to fix welcomed - have a few rough ideas but would welcome the experts.
Much thanks, Nick
Not sure what you mean there Nick, just looks like the woodruff key has sheared, just replace the key.
1 member likes this: N1KK0
Much thanks for the reply - ah a woodruff key - ok I googled and tried to find the correct term for it but couldn't find anything at all - hence my very rough way of describing it.
Any particular tricks or tips with either removing whats left of the old one or affixing the new one in place?
Much thanks again for your assistance.
Hi Nick,
It should just tap out and a new one just pop in, just have the new one sitting slightly lower to the front so that it leads into the slot in the boss a bit easier, tap the boss on and good to go
Thanks Norm.
Yes, came out just like you said. Finding the exact size one to use seems tricky - oddly for the GXv160 engine being very common there's very few correct sized ones listed online. The shaft takes two of them - and they're around Width: 4mm, Height: ~7mm, Length: ~15mm
I've a funny feeling if I go to the Honda dealer they'll want around $15 each for them......dunno if they're the type of thing sold in other industrial fittings stores? Seem like they're used in anything with a driveshaft.
Tempted to try and make a couple using some exact right thickness steel I found in my shed....shape them using the bench grinder. Can't be that hard to do.
Hi Nick,
I usually just go to REPCO when I want a key straight away ,they should have one or just buy one slightly
larger and grind or file the key down.
Max, good idea - I'll drop in there and see f I can get the closest available in sizing.
Much thanks for the idea.
17,712 Registered Users
Topics13,031
Posts107,108
Members17,712
PHP: 8.3.26 Page Time: 0.085s Queries: 32 (0.075s) Memory: 0.6527 MB (Peak: 0.7067 MB) Data Comp: Zlib Server Time: 2025-12-08 07:33:22 UTC
