2 members (Gib, auProspector), 1,243 guests, and 763 robots.
Page 2 of 5 1 2 3 4 5
Jaffa J #94985 17/12/18 04:35 PM
Thanks Norm,
That's the measurement I'll aim at when the new boring bar kit arrives. Probably a few mm out either way would not matter much.
I have a workable version hopefully of the Powertorque sliding plate made. Its a bit rough just made by welding some extra bits on to the center of an old Powertorque base which I cut out with the grinder. It will do to see if there are any other problems when I start her up. If it all works as I hope I'll use it for a template for a new one of 4 or 5mm steel plate .Actually it does not look too bad. Can not actually see very much of it when the engine is installed.
I have left the old FC sliding plate untouched. Hopefully can put an FC back on if ever needed although that might now need a new pulley. I'm just not to keen to make too many non-reversible changes. Look what Norm is doing to his FC 24 which at one stage had a Briggs on it.
I wonder if anyone has ever seen an original Victa Powertorque 24? I would imagine they have done something similar to what I am doing. There is a crossways slot in the base in front of the sliding plate on mine almost right where it needs to be for the muffler.
All the best
Jeff
Jaffa J #94986 17/12/18 04:58 PM
Jeff I have seen a few PT 24's on ebay that I have missed out on but I haven't been up close to one to see what they did. I assume it had the same sliding plate that one I did that had a factory Briggs fitted. The base was different again because it had an extension in the casting and that had a rear sliding bolt hole in it so that it was away from under the Briggs motor. It looked like the PT exhaust slot was in the left hand side so this would mean the motor would be rear facing as per the FC's including the side pulls. When they fitted the PT this way on these they had the top cover without the fuel tank so the motor could be turned anyway and would not look wrong
NormK #94989 17/12/18 06:43 PM
OK Norm,
I think it would look OK crossways with a Utility type cowl for a handle tank (or an ordinary PT cowl with the tank cut off). These have the slots in the cowl running North South when the motor is East West. It might also make the snorkel easier to fit using a standard Powertorque snorkel, without turning the carby upside down.
Anyway this is just a trial at the moment. Can always start again.
Jeff
Jaffa J #94994 18/12/18 12:17 PM
Sorry Jeff, that measurement I gave you yesterday is wrong, I forgot about the spacers under the motor. Got an unmolested one here today and the measurement from the deck to the top of the belt is 34mm. That is fairly easy to measure and you can then work out what you need to do with the pulley.
MF I can't imagine these have a cult following, it is just that they are a superb machine for tackling the really tough jobs and even though they are tough they are light enough to swing and push around. All the other types have to be self propelled because to get them rugged enough they manufacture them using heavy steel material, then because it is self propelled the motors they have to use have to be bigger and heavier than a little full crank motor that can rev its heart out on any angle slope
NormK #94997 18/12/18 01:43 PM
Thanks Norm,
I doubt that mine will be that high. I might need some spacers as well. Full cranks and Powertorques and FC's have the same shaft length don't they? I was just hoping that if I put the pulley on the end of the shaft all would be OK but I had no idea what the correct measurement should be. Still its easier to raise the pulley than lower it.
That one of yours must have a top starter motor, not side pull. Much earlier although probably more common. No sign of a sliding plate or even the bolt holes for one.
All the best
Jeff
Jaffa J #95000 18/12/18 04:16 PM
Yes Jeff it is an early base the same as the one I opened up the other day. Belt height down from the top of the deck is probably the best height to use as long as you are somewhere close to it. If I hadn't sold the last one I set up (it had a factory Briggs on it and I put a F/C on it, on that one I left the boss on it and just fitted the pulley off the Briggs straight onto the boss
Jaffa J #95033 19/12/18 02:56 PM
Wouldn't the half crank be particularly susceptible to the lateral force on the shaft. I have read that even the FC had problems with it.
Jaffa J #95034 19/12/18 03:20 PM
Thanks MF
Not sure, will not know until I get this thing going.
What's the issue, lower bearing wear I guess?
It seems that most of 24's that are around are FC. No one I know has even seen a PT 24 up close let alone pull one apart.
All the best
Jeff
Jaffa J #95036 19/12/18 04:06 PM
I'm still kicking myself, I had a PT one lined up for $80 but it was right out the other side of Melb, hour and a half each way, I was having trouble with my leg and I was not game enough to tell my wife that I was bringing another one home so I eventually told them I wasn't going to be able to pick it up. I am still on the hunt at the moment, one will surface
Jaffa J #95040 19/12/18 05:06 PM
Hi,
I guess that belt tension induced wear on the bearings would be common to any belt applications. I guess that would include the edger and the reel mower. Although by this stage I'm not sure if they continued with either. Of course a 24 works a lot harder than either of those.
.Did they ever stand a PT upright?
Norm $80 would surely be towards the top of your budget. 24's are probably worth it I suppose but you would not want to have to do much to it to sell it again for a reasonable price .
All the best
Jeff
Jaffa J #95051 19/12/18 08:34 PM
Jeff I have paid $200 for a running 24, some cheaper but often $80/$100 is about the figure. One I paid $50 for but by the time I went and picked it up it ended up a 7 hour return trip
Jaffa J #95053 19/12/18 08:38 PM
You'd need a ute, van or AU -BF Ford Falcon wagon to transport it.
Jaffa J #95054 19/12/18 08:45 PM
Trailer is the answer MF, no heavy lifting required, drop the tailgate push down on the handle, front wheels onto the tailgate, lift mower and push forward, done in a couple of seconds
Jaffa J #95058 19/12/18 10:33 PM
Piece of cake, easy as pie. Easier than a regular mower. smile
Jaffa J #95062 20/12/18 07:29 AM
Hi Jeff in answer to your earlier question about standing a PT upright, no reason why it couldn't be done but it would require a different inlet manifold that had the locating tabs on it turned 90 degrees
NormK #95065 20/12/18 10:46 AM
OK Norm,
I paid $95 for the one I have here. It was running but not very well and It looks like its been out in the weather a bit. I thought that was expensive but there were no others anywhere close. I did not try to barter at all. Probably could have got $10 off.
All the best
Jeff
Jaffa J #95067 20/12/18 11:11 AM
Jeff I paid $20 for the one I just pulled the Briggs off, Gadge put me onto that one but it was a fair drive to the Morwell tip to pick it up and a bloke just picked his mower up that I had fitted that Briggs on. I never expected that it would ever run, obviously had been out in the weather for a very long time, but it starts and runs well so he went away a happy man. My mate paid $275 for his. He thought that was a bit expensive when I pointed it out to him but now he loves it, his mower of choice. Before he bought it he asked me why an old mower like that was so expensive and all I said to him was "because they are good." My grandson bought 2 one he paid $80 for it but big end was gone when I got it running, the second he paid $120 for it and that one was in pretty good condition and obviously had not done massive work. A bloke was here with one yesterday I had to fix a wheel on it and when he had it in his ute at work before coming over the maintenance manager spotted it and his only comment was "now that is the real deal"
Jaffa J #95069 20/12/18 05:34 PM
Victor Super Duper 24 -turns jungle into a bowling green. woot
Jaffa J #95154 25/12/18 06:20 PM
Here you go Jeff this one has a Powertorque fitted the motor is sitting flush on the deck, bit expensive for me to get just to find out how it is done.
://www.ebay.com.au/itm/victa-600-slasher-mower/283313806659?
Jaffa J #95155 25/12/18 10:08 PM
They rotated the motor to be north south with the starter facing the side. I guess it's unlikely to tip toward you with such a wide stance.
Jaffa J #95156 26/12/18 06:57 AM
Morning Fellas
My grandfather has a super 24, loves it! we made up an adaptor plate to put a honda 5hp on it years ago. he is in his 70's now and still uses it. have the original engine in a box somewhere (i think)
anyway I just stumbled across this gem, I just wish I was closer!
https://www.ebay.com.au/itm/Victa-super-24-lawnmower/173703433681?_trkparms=aid%3D777003%26algo%3DDISCL.MBE%26ao%3D1%26asc%3D52946%26meid%3D7bf35564b67447b08839a41425b304db%26pid%3D100009%26rk%3D2%26rkt%3D10%26sd%3D283313806659%26itm%3D173703433681&_trksid=p2047675.c100009.m1982#shpCntId
Hi, Thanks everyone,
Looks like there are a few more 24's about. They definitely fit those factory PT's north south. They are using a Utility cowl but the slots are crossways. Oh well I have got it wrong. I thought it looked better the other way with the slots North South like every other PT. I would love to see their sliding plates although the base is probably different.
I did originally look at that way of fitting mine but its not easy as the slots seem to line up almost perfectly with one of the PT bolts, the long one. I think you could probably do without that long one as there are still three others and they would be fine. The pulley would be interesting as well.
I was hoping for a factory look for this conversion but it seems I will be disappointed. They are grey now not orange as well and I am certainly not going to paint over that excellent orange paint they use.
I have gone too far now with my first attempt at a sliding plate. I will try it and see how it goes. I'll keep you all posted, Maybe even a photo. I have the engine sitting on the base with the new sliding plate now. I think it looks fine. Still waiting on lathe tools for the pulley.
That other 24 looks good too. A top starter engine with the same sliding plate as mine. Well worth $100 I think. Where is 2210? No where near Brisbane or Eden that's for sure.
All the best
Jeff
Jaffa J #95158 26/12/18 08:41 AM
It is in Sydney Jeff I had seen it but didn't mention it because you were going the PT way and being in Sydney was too far for me. I don't think you have much choice as to which way the motor goes because of the existing slots in the base. Yes the one I sold last month was a grey base with originally a Briggs on it. In hindsight I probably should have put a PT on it and then I would have had all the information on what was what
NormK #95182 27/12/18 10:48 AM
G'day Norm,
Interesting that the Briggs was original fitment on that 24; I wasn't sure of that, when I looked it over.
Those Briggs Quantum 50 series 190cc models seem to be a lot better engine than I'd really expect of a sidevalve with a plastic camshaft; I have one on a Masport alloy chassis Maxicatch 550 - it's my 'everyweek mower'. The US built ones, at any rate - mine's one of those.
Jaffa J #95184 27/12/18 11:53 AM
Hi Gadge, no the Briggs was not an original fit, it was a real bush job that had been jacked up on a bit of plate but it did what it had to do. I have now cut a hole in the center of it so I can fit and remove a motor on it with the pulley still on it. Took me about 7 hours to remove the motor and get the pulley off. Easy when you put things together and weld bits in place and getting those rusty pulleys off in situ can be a real pain.
NormK #95187 27/12/18 12:38 PM
On looking at that factory PT 24 again, I notice that the carburetor is upside down as it has to be to fit the snorkel that way. Interesting that they did that even in the factory. Nothing wrong with it I suppose.
Also, that looks to be a special snorkel. With my idea I think any PT snorkel will fit. I'm hoping to get it so that any PT will fit straight on, without even taking the blade boss off.
All the best
Jeff
Jaffa J #95190 27/12/18 03:09 PM
Hi Jeff another advantage with that carby, it can be swapped around depending on what mower it was being fitted to. Once you get it set up ant PT will fit it is still the cowl that might look a bit wrong
NormK #95195 27/12/18 04:57 PM
The whole mower looks a bit wrong, so it wouldn't matter!
Jaffa J #95201 27/12/18 11:27 PM
Found this Powertorque edition of the 600 slasher.
Thanks MF,
What do you mean the whole mower looks a bit wrong? Beauty is in the eye of the beholder and anybody who has used a Super 24 will find a way to think they are beautiful.
Thanks for the video. Good views of a factory PT24. It looks like they do not actually need a sliding plate anymore. They must let the PT bolts slide straight in the base. Base must be quite different to mine.The belt tensioner in the front is a good idea.
Thanks again for your interest.
Jeff
18,091 Registered Users
Topics12,750
Posts106,781
Members18,092
