0 members (), 1,081 guests, and 1,569 robots.
#104594 21/03/20 06:04 PM
A friend was sick of his Talon, he bought a new mower..........
It turned up in my carport this morning..............
Looks good...............he said it worked a bit then couldn't start......
Anyway, no spark...
I took the starter off and see a peg was loose ....... took the cover off and could not belive what I saw.
The threaded peg, was a coil support..... the coil was rubbing against the flywheel... hence no spark.
I cleaned up the coil and flywheel with a wire wheel on the drill.
Set the coil air gap to 10th inch.Still o spark, so I disconneted the coil cut out wire, Now a spark.....
Put it back together. I had to use vice grips to tighten the coil peg as there was no nut edges on it.....
Anyway it started with the electric drill start, and I mowed a bit of the front lawn..... smooth engine, as it didn't look like it has done much work........
It's 19 in cut..... a bit of a monster...............
Good thing there speedy, if the motor gives up you can always fit a Powertorque to it. Yes they are a bit of a tank, I can't imagine why some manufacturers build them big like that when steel costs money. MTD also springs to mind
So I take this to mean you succeeded in wacking a PT on your Talon base NK?
I haven't fitted the motors on these MF, I painted them but haven't had a chance to finish them off but I will probably do that today depending on what else happens.
How does the Talon base look after the repaint? Outstanding I expect. Let's hope the Powertorque succeeds.
I mowed the front lawn, turned it off, now it won't start, i'm sick of it already..................
They aren't the best speedy, a very poor cousin of the Briggs
I've had one with a disintegrating brass tank filter clogging the carby.
They aren't the best, but one of my friends has one and beside the carby clogs, and wheels falling off, it has been reliable - and it has been hammered hard on a 1200 sqm block.
problem solved............. scrap dealer
What about the base and wheels?
I have a good Victa base with 8' wheels waiting for my next PT project.....
Just didn't want junk laying around.
You might think different if you come into two PTs.
MF,
What I really really want is a unility frame for a PT...................
Make up a beast...............
Speedy I should have remembered you don't like using catchers.
18,068 Registered Users
Topics12,746
Posts106,765
Members18,069
