2 members (Red Rum, AndrewD), 5,814 guests, and 945 robots.
#103391 08/02/20 09:45 AM
Does anybody have a method of removing the speed nut on these line trimmers that holds the inner cup up tight on the shaft. I usually don't bother with these things but I pulled a couple out of the shed and got them running but they need the bump heads replaced. People keep asking me for line trimmers and I just tell them they are not worth the trouble when you can get them on ebay for about $150 with 4 or 5 different cutting blades
NormK #103393 08/02/20 10:28 AM
I thought that part was pressed and couldn't be removed. Maybe another shaft may fit.
NormK #103395 08/02/20 04:03 PM
You need to lever the washer side up and the use a wire cutter to brake the washer. I have plenty of the washers to re-fix the heads. cheers2
NormK #103396 08/02/20 08:24 PM
Norm, I have levered it up slightly with screwdriver, then grabbed with vice grips, and twisted back and forth until it comes all the way off
NormK #103401 09/02/20 12:59 AM
As said those Homelite style heads push nuts has to be levered out or cut. What I use now is a modified small flat tip screwdriver that bent into a semi circle ( around 90 degree arc) as to slip under the nut to get to the catch fingers and lift them up as I go around the push nut so I can save the nut for reuse. Once you get it off then you can remove the adapter if needed just note that many of these are NLA separately. Replacement of the same style usually have a new push nut in the packaging or at least it is that way here.
I even use the same style tool to get the push nuts on the MTD front spindle axles off
Mark Tasmania, Mello Mac, beanbandit, Dctga, AndrewD
18,233 Registered Users
Topics12,777
Posts106,881
Members18,234
